base gasket leaking oil up through cylinder bolt
  • speedlimit85
    • Jan 2017
    • 433
    • Gainesville, Fl.
    Has anyone tried Hylomar to stop this kind of leak?
    80 G
    • 2053
    Probabaly a silly questiom, bit you are sure it's not the valve cover? All of mine leak after some thermal cycles, then I have to tighten them 2,000 miles after I install them.
      • 8766
      Once this starts leaking like this, it's like Whack a Mole, fix one leak and another pops up shortly after.
      • speedlimit85
        • Jan 2017
        • 433
        • Gainesville, Fl.
        I did change the valve cover gasket and it looks dry.
        It can fool ya... leaks travel.
        80 G
          • 8766
          This is the area that is prone to leaking, the smaller is the stud/bolt hole. See how close it is to the faulty O-ring.
          And to add, there is an awful lot of oil being slung around in that cam chain tunnel right nearby. I think some kind of sealer would be a good idea around this area when reassembling, maybe an anerobic type so there is no rush fitting the pistons/rings back in.
          Click image for larger version  Name:	IMG_20240502_233515.jpg Views:	0 Size:	166.3 KB ID:	879528
            • 5061
            I stopped a leak near my right knee when sitting on the bike. Oil was coming up from the crankcase along one of the long bolts that holds the head on. I squeezed some RTV Ultra Black around the bolt where it goes into the crankcase. It hasn't leaked for many years since that fix.
            • speedlimit85
              • Jan 2017
              • 433
              • Gainesville, Fl.
              Yes. I want to try something like that.
              To do it right, I would need to brake cleaner spray and brush around each bolt then caulk it with hylomar or permatex equivalent.
              https://www.amazon.com/Valco-Cincinn...76&sr=8-1&th=1
              I heard Hylomar was used to stop fuel leaks on aircraft.
              80 G
              • speedlimit85
                • Jan 2017
                • 433
                • Gainesville, Fl.
                I just stuck my fingers around each bolt with the bike cold.
                Only 2 are wet: front and back inside right. So that would be the one o-ring to the right of the chain.
                80 G
                  • 8766
                  Yep, or coming from the cam chain tunnel itself.
                  • speedlimit85
                    • Jan 2017
                    • 433
                    • Gainesville, Fl.
                    I just tried that. Thank you for the idea.
                    80 G
