Has anyone tried Hylomar to stop this kind of leak?
base gasket leaking oil up through cylinder bolt
Tags: None
Probabaly a silly questiom, bit you are sure it's not the valve cover? All of mine leak after some thermal cycles, then I have to tighten them 2,000 miles after I install them.-Mike
Previous: '68 Motoguzzi 600cc + '79 XS750SF 22k miles +'84 Honda V65 -
Once this starts leaking like this, it's like Whack a Mole, fix one leak and another pops up shortly after.2H7 (79) owned since '89
☮Comment
80 GComment
This is the area that is prone to leaking, the smaller is the stud/bolt hole. See how close it is to the faulty O-ring.
And to add, there is an awful lot of oil being slung around in that cam chain tunnel right nearby. I think some kind of sealer would be a good idea around this area when reassembling, maybe an anerobic type so there is no rush fitting the pistons/rings back in.
☮Comment
I stopped a leak near my right knee when sitting on the bike. Oil was coming up from the crankcase along one of the long bolts that holds the head on. I squeezed some RTV Ultra Black around the bolt where it goes into the crankcase. It hasn't leaked for many years since that fix.Skids (Sid Hansen)
Yes. I want to try something like that.
To do it right, I would need to brake cleaner spray and brush around each bolt then caulk it with hylomar or permatex equivalent.
https://www.amazon.com/Valco-Cincinn...76&sr=8-1&th=1
I heard Hylomar was used to stop fuel leaks on aircraft.Last edited by speedlimit85; 05-04-2024, 09:10 AM.80 GComment
I just stuck my fingers around each bolt with the bike cold.
Only 2 are wet: front and back inside right. So that would be the one o-ring to the right of the chain.80 GComment
I just tried that. Thank you for the idea.I stopped a leak near my right knee when sitting on the bike. Oil was coming up from the crankcase along one of the long bolts that holds the head on. I squeezed some RTV Ultra Black around the bolt where it goes into the crankcase. It hasn't leaked for many years since that fix.80 GComment
