First bike. 79 xs1100 special
  • Keith805
    • Apr 2023
    • 56
    • Indianapolis
    #76
    Originally posted by Schming
    Hi Keith, good score. The bike looks to be what you stated a '79 but the clutch cover has no kick start shaft protruding. Check the numbers on the engine as it may have been switched. If the engine is original with only 9600 miles on her you got a steal
    Just got home and took a look at the engine numbers
    4h3-002067 engine
    3h3-009009 frame
      • 2083
      4h3-002067 engine
      3h3-009009 frame
      According to the following link, your engine is originally from an '80 LG, but the carbs your working on are early carbs '78 - '79
      https://xs11.club/forum/miscellaneou...identification
        • 1911
        4h3-002067 engine
        3h3-009009 frame
        Good catch Schming. Brings up another issue that needs to be verified. Keith... on the airbox on the side that faces the engine when installed there are two nipples where the hoses from the two interconnect brass tees come back to it. Are those actually holes or are they solid and closed. I am asking because the carbs are for sure original to the bike and now we know the engine was an 80 LG or midinight specail engine. Hopefully all that was swapped was the engine and everything else is still original to the bike. Those carbs have to vent to the airbox from those upper tees in between the carbs in order to work correctly.
        • Keith805
          • Apr 2023
          • 56
          • Indianapolis
          #79
          Yes they are not blocked and they have that brass tube going in
          • Keith805
            • Apr 2023
            • 56
            • Indianapolis
            #80
            Okay so I took all the vinegar out of the tank today and retrieved all the screws I had in there and came out looking pretty sweet. I went and found a spot that sells 90 and filled her up so it wouldn’t flask rust after I rinsed it a bunch of times. Now I’m just waiting on the sender unit gasket and battery that I ordered. MAN the suspense is killing me to see if this thing fires up. I need to order oil and filter before anything else and take care of that.
            So what’s the deal using a pressure washer to clean the bike? Is that a no no or what should I keep in mind when doing so….
            • Keith805
              • Apr 2023
              • 56
              • Indianapolis
              #81
              So the motor that’s in there is that still a good running engine? Well I know I’ll find out soon enough but Is it better then the original?…. Well that being said I’ll make sure to get all engine parts and what not pertaining to that engine model..
                • 724
                Yes, The 80 engine is a good running engine. But is it a better runner than the 79? Probably not. I can only speak from my riding experience, having ridden and owned both. The 79 seeems to be a bit faster and a bit stronger and pulls a bit harder. That's just the way it feels to me when riding. Someone else will probably be able to verify if this is true or not with some technical/ engineering facts that are beyond me!
                  • 2066
                  A pressure washer can push water past bearing seals and other places water would not normally go- I wouldn't do it unless I getting ready to disassemble the bike.
                  Many of us have noticed the '78-'79 engine has a surge. It comes on really strong around 3700 RPM- noticeable more than the '80 and later engines. However, the '80 and later engines seem to have a broader power range. They are about the same performance overall, but the earlier engines have that really pleasant surge. This is just my personal feeling, not based on any data.
                    • 8798
                    ^^^ Yep, about 3700 the power band really kicks in on the early motors.
                    07 Triumph Tiger 1050
                    • Keith805
                      • Apr 2023
                      • 56
                      • Indianapolis
                      #85
                      Thanks fellas. Yeah I just wanted to get some input and thoughts on that. The battery should be here tomorrow. I’m taking a heat gun home today as I can’t let it sit in the sun and what not because it’s going to rain. I wanted to let me it all heat up outside when I put it in to soften the rubber up a bit before I try and put these carbs back in. I’ll be sure not to over heat them..
                        • 1911
                        Just take some wd40 on a rag and lightly wipe the insides of the manifolds. Don't drench them mind you. The carbs will slide right in.
                        • Keith805
                          • Apr 2023
                          • 56
                          • Indianapolis
                          #87
                          Thanks Cajun. Okay so they are on the engine manifold now but quick question I’m having issue with air box I got it in but I’m not sure if this too bracket goes on top or bottom of the frame… I can’t get the boots over the top edge. Please advice.
                          • Keith805
                            • Apr 2023
                            • 56
                            • Indianapolis
                            #88
                            Disregard last post I had left in 2 bolts on side bracket that was messing me up
                              • 1911
                              I am sure you figured it out, however the bracket from airbox should be on top of frame. Looks like you are making good progress. When I get into a fresh restore my main objective, as I am sure I am not alone, is to get the bike running. Once you arrive there then you can sit down and figure out what you want to do as a final product and budget appropriately. just remember, brakes and tires are both things that should not be overlooked. Old tires should be replaced and being able to stop and not having your calipers drag are important.
                              • Keith805
                                • Apr 2023
                                • 56
                                • Indianapolis
                                #90
                                Copy that! Yeah I’ve never restored a bike and what not. I do electromechanical work as my trade and when I was younger worked in my step dads European automotive shop so I know basic automotive things yknow. Exactly my main objective at this point is fuel system and engine and see if it even rocks and rolls. Breakers calipers and masters front and rear for SURE need tlc. I haven’t even started cleaning the bike haha. Thank you so much for your wisdom guys…
