the saga continues !!!!!!
  • Tropic-al
    • Nov 2009
    • 176
    • Tampa, Florida
    #61
    Hi Tony. Where did you get the adjustable air valves described in your vacuum line post above?
    All I have found are too small in an aquarium place.
    79 XS1100F.
    TC's fuse box.
    SOFA filter.
    Venture cam chain adjuster.
    Tkat fork brace.
    Progressive fork springs.
    • Tonyxs11
      • Oct 2022
      • 271
      • Cumbria UK
      #62
      Hi mate, I used one of the air valve that came with my balancing gauges just as an experiment, I did see some on UK ebay though.
      I have these gauges.
      • Tropic-al
        • Nov 2009
        • 176
        • Tampa, Florida
        #63
        Thanks for the reply Tony.
        Don't want to spend $ yet on a full set of synchros.
        Mine are good but don't have the air valves and so they're real hard to read accurately.
        Everything I've found is for smaller sized hose as in fish aquariums.
        79 XS1100F.
        TC's fuse box.
        SOFA filter.
        Tkat fork brace.
        • Tonyxs11
          • Oct 2022
          • 271
          • Cumbria UK
          #64
          you can experiment with some sort of restriction in the hoses that might help !! a thin tube of some sort inside the hose will dampen the vacuum pulses. or small pilot jets.
          • Tropic-al
            • Nov 2009
            • 176
            • Tampa, Florida
            #65
            Good idea. I'll try it.
            Thanks.
            79 XS1100F.
            TC's fuse box.
            SOFA filter.
            Tkat fork brace.
            • Tonyxs11
              • Oct 2022
              • 271
              • Cumbria UK
              #66
              side panels finally done, bike is basically finished but will be changing the forks for standard ones when i find a good set, now to get some miles on it
                • 735
                Looking good Tony! When you change over to the standard forks, will you keep the lowers black? If so, have you considered black headlight ears to go along with that?
                • Tonyxs11
                  • Oct 2022
                  • 271
                  • Cumbria UK
                  #68
                  no mate, i like the shiny legs and chrome headlight brackets. I'm all for modifying bikes and done it to almost every bike ive owned !!!!! BUT i'm going for the standard look as much as I can, saying that it will be a modified bike as it started life as a 79 SF if I had plenty of cash i would go for a chain conversion with wider wheels and better forks, a bit like my GSX.
                  • Tonyxs11
                    • Oct 2022
                    • 271
                    • Cumbria UK
                    #69
                    some small changes, painted the seat trims and polished the end of the engine covers, i think they look better polished. bike also running sweet now.
