1980 xs1100 rear master cylinder rebuild
  • yellowjacket
    • Mar 2021
    • 16
    I took the rear master off and cleaned it thoroughly. I can see through all the holes. I put the rebuild kit in and I can't get it to pump the brake fluid. I must have something out of order. I have searched for a picture of the order of parts on the shaft but can't find one. The service manual is not that clear. Does someone have a picture to share that would help. Thanks.
  • 2WheelFun
    • Aug 2020
    • 266
    • Pittsburgh PA
    You need to bench bleed it. Basically making a seal with your finger while pumping it to prime it. The seal can be made at any of the line joints but the closer to the master the better.
    1979 XS1100 Special
    1980 XS1100 Std parts bucket
    1987 ZL1000 Eliminator
    • yellowjacket
      • Mar 2021
      • 16
      OK. I still need to get the order of the parts.
        • 734
        sorry, don't have a picture, but will this help you at all?
        Rear MC rebuild - sequence of parts - XS11.club Forums
          • 1987
          Bleeding the brakes is a much easier job if you would invest in a mity vac or something similar. Much easier to just pull the fluid through versus trying to get the air out. Especially works well on the front brakes.
          • LenB
            • Nov 2020
            • 160
            • Winnipeg, Manitoba, Canada
            After filling the master cylinder reservoir and pumping the (bad word) out of the brake pedal to no avail, I realized that the necessary vacuum could not be created without priming EVERYTHING. Stripped the MC down AGAIN and used a kid's large liquid antibiotic syringe to inject brake fluid directly into the plunger cylinder and the caliper. Now, with brake fluid in the critical parts of the system, I finally felt some pressure at the pedal and successfully bled the air out of the system. And, yes, I too incorporated a simple hand-operated pumping system which greatly helped the bleeding process. If all parts are installed proprely, it's time to celebrate when you feel good pressure at the pedal!
            1980 XS1100G (one owner-me)
            1984 Honda VF750S V45
            Owned - 1976 XS750D
            Owned - 1972 Honda CB750
            Owned - (unknown year) XS650
            • yellowjacket
              • Mar 2021
              • 16
              Thanks for the replies. I now have rear brakes. Put the master back together with the above listed order. Primed the caliper with brake fluid. Attached a long hose to the bleeder bolt and primed with my mouth on the other end while I pumped the master. Worked great. Slowly coming together.
                • 2138
                ... Attached a long hose to the bleeder bolt and primed with my mouth on the other end while I pumped the master. Worked great. ...
                I do this too!
