Rear MC rebuild - sequence of parts
  • dbbrian
    • May 2016
    • 596
    • Stratford, Ontario, Canada
    I find the parts diagrams are all fuzzy. Is there a clear one avaialble to see the order or sequence of parts in the rear MC rebuild?
    See my proposed order / sequence.
    1. Does the little washer on the bottom left of picture go there or sonewhere else?
    2. Does anyone know which rubber seal goes on where? (They are not the same - my guess is the thicker one goes on first so it ends up in the middle of the plunger.
    3. The Spring goes on with the tapered end against the plunger?
Name:	Rear Brake rebuild order of parts.jpg
    Think I got the resevoir parts in order.
    Thanks
    • 8962
    Ok, this is the order left to right...
    spring/cupped washer/smaller rubber seal/thin washer/plunger rod/larger rubber seal. Both rubber seals have the cupped end facing towards the fluid side of the plunger rod.
    That little washer goes behind the end smaller rubber seal by the plunger rod.
    • dbbrian
      • May 2016
      • 596
      Thanks Bikerphil.
Name:	Rear MC Rebuilt.jpg
        • 8962
        You bet, the unit looks great now, like new.
        • red bandit
          • 970
          • central michigan
          Can I send you mine? jk. Good job.
          79 SF parts bike.
