Brake upgrades for the Special Front brakes?
  • XS-play
    • Nov 2013
    • 109
    • Austin, Tx.
    Just wondering if anyone has come up with an upgrade or fix for the lackluster front brakes on the Specials? I would like to keep my 1980 SG as close to OEM as possible, Pad compounds and such are open for debate. Has anyone delved into why the Special brakes are so bad? As far as I can tell both Standard and Special brakes look very similar, as far as Pad area and such. There is the odd taper on the Special units, how does this relate? I saw a discussion a while ago about getting the special pads mixed up. I don't see how that could be possible. Am I missing something here?
    Peace, Wolf
    80 SG
    81 Midnight Special (R.I.P.)
  • auxtian
    • Sep 2002
    • 136
    • Berkeley, NSW, Australia
    Blue Spots from an R1
    • XS-play
      • Nov 2013
      • 109
      • Austin, Tx.
      Thanx Auxtian
      Is there a specific year or group of years?
      80 SG
        • 268
        GET BRAIDED STAINLESS BRAKE LINES!!! BY far the best upgrade to make for front and rear,,,,measure length of lines with a string, or skinny ruler,,,go to ebay, type in ss. motorcycle brake lines and there is a ton of sellers, colors, etc very cheap around 10.00 a line. All are DOT approved, I have them on three different bikes and they work great,,,,,the best upgrade for the old xs1100's you can make. Clean your pads, sand lightly, pop on these lines and it will be a two finger stop on the front brakes, not the mushy feel but FIRM and racy............best 30.00 for all around solid braking....Mike in San Diego
        • auxtian
          • Sep 2002
          • 136
          Originally posted by XS-play
          Thanx Auxtian
          Any of the blue or gold spots will do, just need the adapter's
          Mal Pitman in Australia or Miti in Scotland can help there.
          Also used on early FJR and XJR models
            • 8798
            I could be wrong, but I do not believe anyone makes a caliper adapter plate for the oddball Special forks. Member Topcatgr58 made his own but not very easily.
            Click image for larger version  Name:	Special Fork.jpg Views:	0 Size:	152.0 KB ID:	865635
            Link to the bracket fabrication...
            https://xs11.club/forum/idle-talk-fo...rk-upgrade-mod
