XS11 "SPECIAL" front brake/fork Upgrade Mod
    Hey folks,
    As you might be able to gleen from the title of this soon to be marathon post, I have embarked on an expedition of unknown frustration!
    My front caliper's pistons had become frozen after some 12 years after my last rebuild/cleaning. So...I tore them down to clean and rebuild them again, but I discovered more severe pitting in the pistons than had been then previously, and would need to replace them. I had seen Crazy Steve's Standard Fork caliper mod with the Harley dual piston calipers and a simple mounting adapter bracket and a "little" modding of the calipers themselves. I thought I would attempt to do a similar mod for the Special, to get rid of those funky slanted pads, and to put some modern dual piston calipers up there, not so much as to be able to do a STOPPIE , but to have more modern serviceable parts, pads and such...and hopefully get a little more braking power!
    I first measured the clearance between the inside edge of the Rotor, and the wheel spokes, and found it to be about 41mm. I was concerned about clearance for the more modern 4 piston systems, as well as the need for possible modding to allow room for our thick 7mm rotor vs. modern bikes which have ~4mm thick rotors. So..I decided to look for a dual piston design. There were plenty of 4 piston units from Yamaha FZ type bikes, but I found a set off an '05 FZR600 with only 2 pistons per caliper. I didn't know how thick/big it was from the edge of the inside brake pad to the edge of the caliper housing, but I figured it would be narrower than a 4 piston system, I took a gamble and ordered them from ebay. ~$50.00 for the pair plus S&H. That's about how much I would have had to spend on just the replacement OEM special pistons, not to mention rebuild kits! And the calipers came with the brake pads, almost new thickness, and they were organic fiber, not metal sintered type.
    Once I received the calipers, I could then proceed with the design for the adapter/bracket. The special uses a fairly pronounced buttress that has a groove for the brake pads to slide in and provides most of the strength of the brake pads stopping power, the single 8mm bolt through the special's caliper is just to hang the swivelly caliper and slanted pads around the rotor, wedging the pads against the buttress... so the bolt doesn't have much stress on it.
    I had first thought about trying to keep the forks STOCK, both trying to come up with a bracket design that could be fashioned at home with simple tools and also allow the option of going back stock if desired! Below are a series of photos showing the fork buttress area, the pads groove, the Z shaped recess from the OEM bolt plate location down into the buttress area, etc.!
    I had some 1" thick aluminum plate material, and was thinking about cutting 1/2 of it's thickness away to fit alongside the large buttress plate as well as into the recesses of the buttress, etc.!
    However, due to the casting imperfections, the edge of that buttress wasn't at a true 90 degrees to the mounting bolt plate.
    A few other mockups with the preliminary bracket piece, already getting complicated!
    And as shown above, I was still looking at the possibility of needing an additional plate to go across the entire mounting area, etc.! I wasn't thinking out of the box, I was limiting myself to the material I had on hand...1" thick plate!
    Then I realised that I would NOT be going back to stock with this mod, and that it most likely will not be an easy do it yourself bolt on type mod, so I decided to open up my options to design and fabrication. Crazy Steve was very instrumental in assisting me in thinking outside of the box, and without the constraints of going back stock, we made some drastic design changes.
    I also had a log of 4" thick x 6" long aluminum I was saving for another project, but decided I could use it to provide some thicker/wider material for the new design. Without the constraints of STOCK, Steve first suggested that the inner rotor guide be removed from each fork slider.
    Then, to simplify the attachment area, the area below the OEM bolt contact plate would need to be removed to make a more simpler 2 level surface with just one 90 degree bend/step between them.
    With this in mind, I started on the rework of the design and the fork modding. I used a metal cutting band saw to remove the inner rotor guide from each fork slider.
    This shows the area that is to be machined/removed from the recess area of the fork.
    Back to the calipers, here are both of them, the one on the right was how it arrived, and it has a smaller ~4mm diameter screwdriver stuck between the pads, and I noticed that there was some piston protruding from the caliper housing, and I hoped that they were just stuck there due to the smaller rotor they were used to being around, and once I pulled the other one down, removed the dirt/grime, cleaned and relubed the O-ring with brake fluid, the pistons went back in much farther, and you can see by the one on the left that there's more room between the pads by example of the larger ~7mm diam. screwdriver placed between those pads! Okay, first clearance problem solved, will fit around the XS's 7mm wide rotor without any $$ grinding work to thin the rotor!
    Then I took the caliper bracket and placed it over the rotor to see how much clearance there was....not much!
    This shows the amount I ground away from the inside edges of the caliper mount bracket to allow room for the rotor!
    Next was on to the machining of the fork, I/we assumed that the OEM mounting plate surface was perpendicular(90) degrees to the direction of the whole fork, so I made a little jig that was measured to be 90 degrees on 2 sides, and bolted it to the fork, and then secured it to the machine/rotary table with additional clamps. I was then able to machine FLAT the rotor guide area.
    I was then able to use that machined flat surface to position the fork on it's other side to allow machining of the remaining recess area...my 1/4" diameter milling bit wasn't long enough to do the whole recessed area without flipping the fork over!
    This is just the second fork showing the entire recessed area machined flat like in Steve's earlier diagram.
    Here are both forks, recessed areas machined, and showing the plan for the placement of the larger securing bolts to hold the adapter brackets for the calipers!
    Drilling and tapping the 10mm x 1.25 pitch was a challenge in that location of the fork, as well as at that angle!
    Next are a few photos of the finished adapter bracket alone and then mounted to the fork.
    Here's the right caliper mounted up to the fork/wheel while they are still not connected to the frame for a mock up!
    (Continued in next post....went beyond the 30 images per post limit!)
    Front brake fork upgrade mod continued!
    And now here they are fully mounted to the bike, forks in the triple trees all assembled, and the adapter brackets and calipers mounted, plumbed and fully functional. There was still a bit of "fitting" the calipers to the adapter brackets (grinding) so that they would be properly centered around the rotors and not be rubbing or dragging.
    This last view is a combined view from slightly different angles just showing the calipers from below.
    My master cylinder was also slightly grunged up, had to clean it and the spooge hole out, refill and then bleed, bleed, bleed! BTW, when I did my initial bike restore/rebuild in 2000, my OEM MC was too far gone, I got one from a local bike breaker yard, but didn't realize/know at the time that the XJ MC was for only 1 caliper! It was a little soft with the OEM vinyl lines, but once I put on SS braided lines, it stiffened up nicely and was adequate for driving the OEM pair of calipers. There was a little bit more travel in the lever, but provided a little more "feel" in applying the braking force.
    My first road test wasn't very impressive, but Steve reminded me that the new (used) pads needed to "BED IN" to the new rotor, and after several days of local riding, they seem to be getting stronger every day. Surprisingly my OEMs had a pulsing sensation and I thought that the rotors were slightly warped, but during the fitting process I spun the wheel many times and watched the rotors and they didn't appear to wobble sideways like a warped one would, and now the brakes are smooth and even when I apply them, no pulsating sensation!
    The routing of the speedo cable is a bit more of a bend around the side of the caliper, I've got a new one on order along with a 6" extension so that I can route it BELOW the caliper for a more gentler bend coming from the fork/speedo drive unit.
    SO....now we can see that it's possible to mod the special's forks and make an adapter mounting bracket for some modern calipers, but unless you have access to a milling machine as well as a variety of other metal working tools, grinders, saws, etc., this particular mod is not easily done, and I would highly suggest you just buy the replacement pistons and rebuild kits and fix your OEM calipers, get some SS braided lines, rebuild your MC or put a new one on and call it a day!
    PHEW!
      Wow, 47 views and not one comment??
      I'm surprised, but then again, I guess you all were just too tired after reading and viewing the marathon post to comment??
      Not even a snippett from Fredintoon....weren't you looking for a way to get rid of your slanted pads/calipers on your machine?
      As stated, it was a mod born more out of necessity as well as just an experient to see if it could be done and what would it take to do it properly, safely, and strong.
      • DeanR
        • Jan 2005
        • 1499
        • Finger Lakes NY
        Another ambitious TC Engineering project ! Did you use your forks or did you have a spare set to experiment with?
        80 SG
        81 SH in parts
        99 ST1100
        91 ST1100
        • CRXSi90
          • Jun 2004
          • 400
          • Madison, Wisconsin
          I'm surprised, but then again, I guess you all were just too envious after reading and viewing the marathon post to comment??
          Is this your personal shop? I can definitely appreciate the ingenuity to accomplish this!
          '81 XS11H Venturer - holed up in storage while life happened since 07/08/04
          '81 Kawasaki KE175 enduro - 63 mph of smokey fun, now with collector plates!
            Everybody is looking for a easy way to do this.... This ain't easy, but then again it's not all that hard if you have the tools...
              My brakes work just fine with the "Wierd Harold" calipers.
              • geniusloerts
                • Jul 2007
                • 420
                • fayetteville, Arkansas
                I was just thinking about this this morning as I hopped on the bike to come to work and the front brakes were dragginga and had a rotational sqeak. I was hunting for a complete fork upgrade too. I rebuilt the special forks, calipers and cleaned the MC last year but still had drag problems that have been driving me crazy.
                and yes I'm alive
                1979 XS1100 SF "Black Goblin"
                -Pod Filters
                -4-1 pipe
                -larger jets for carbs
                1982 XJ1100 "Black Sheep"
                • mikubuilder
                  • Jul 2011
                  • 548
                  • Westland, Mich.
                  great mod TC, will be sending you my forks soon
                  Nick
                  1982 Virago 750 (it's alive!)
                  • XS1100 Newbie
                    • Jun 2009
                    • 1106
                    • Battle Ground, Washington
                    I think you may have a side business there TC. Cost prohibitive i am sure. Great job though.
                    1980 XS1100LG Midnight
                    1991 Honda CBR1000F Hurricane
                    A cold beer and another one!
                      • 6765
                      Knowing TC this was all done in his garage...great mod TC... like the fabricated brackets...thats not for the basic skill set challenged... LOL...someone said its all in the tools but without the knowledge and skill to use them one wont get far.
                      2005 Honda SilverWing 600
                      2018 Honda PC-Xpress 150
