exaust cracked
  • speedlimit85
    • Jan 2017
    • 448
    • Gainesville, Fl.
    exaust cracked
    Maybe I take too many bumpy back roads. It's not too rusty, but today I heard rattling and there is a big crack through the right side just in front of the cross over.
    Can this be repaired, welded, JB? Could be hard to replace. I rode aroundy with it like that today, It's not dangerous yet right?
    80 G
  • speedlimit85
    • Jan 2017
    • 448
    • Gainesville, Fl.
ID:	865330 Click image for larger version
    80 G
    • speedlimit85
      • Jan 2017
      • 448
      • Gainesville, Fl.
      Trying jb weld exhaust...
      80 G
        • 7818
        They rust from the inside, so you are probably close to "end of life" on the factory system. The JB may give you another year or two, so it's a good first try. If you know how to weld, or have a GOOD local welder, that could give you about four more years.
          Speedlimit,, tack weld in four locations with a wire-feed welderl while exhaust is in place. Remove right side exhaust and finish welding break preferably using a torch and welding rod. Torch welding this spreads the heat across pipe while welding. Grind it smooth with an angle head grinder using a flap sanding disc. Paint the area using a can of Dupli-Colors High Temp Silver. That fix will last rest of bikes life. Just a tried and true procedure from a certified welder/fabricator.
            BTW, Dupli-Color brand spray paints are primarily located at your local NAPA dealers. It is also a high quality paint brand that stays looking good for many years!
            • 2WheelFun
              • Aug 2020
              • 266
              • Pittsburgh PA
              I agree. Go right to a good weld shop. Do not use any epoxy as it will contaminate any weld repair.
              1979 XS1100 Special
              1980 XS1100 Std parts bucket
              1987 ZL1000 Eliminator
                • 1987
                I had this happen on my original to me MNS. I took the bike to a reputable welder so that he could spot weld it to hold it together. I then took the exhaust off the bike and brought it back to him to finish the job. It would be best if you can find someone that can do TIG.
                • speedlimit85
                  • Jan 2017
                  • 448
                  • Gainesville, Fl.
                  better Click image for larger version
                  80 G
                  • 2WheelFun
                    • Aug 2020
                    • 266
                    • Pittsburgh PA
                    Hit it with a brush to clean off the oxidation and put a bit of high temp paint on it to keep it from rusting out in the heat affected zones of the weld.
                    1979 XS1100 Special
                    • speedlimit85
                      • Jan 2017
                      • 448
                      • Gainesville, Fl.
ID:	890907 Click image for larger version
ID:	890906now the left side crack is all the way through...How hard is it to remove for weld to go all the way around? would I need new exhaust gaskets?
                      80 G
                        • 7818
                        I had to do my special exhaust this past spring. Right side cracked all around. Lucky for me I have a TIG welder and was able to weld it up. I did add some extra steel to help support the pipe at the break. The hard part is trying to get a clean weld, between the carbon, nickel plating, and thin "good" steel to weld on. I know it's not pretty, but it should hold for another 30 years with any luck. My next task is going to build a complete exhaust system for the 1978 I'm working on. That is going to be a 4 into 1 made of stainless steel.
                        Click image for larger version  Name:	Exhaustr.jpg Views:	0 Size:	135.0 KB ID:	890909 Click image for larger version  Name:	Done2r.jpg Views:	0 Size:	241.4 KB ID:	890910 Click image for larger version  Name:	Done3r.jpg Views:	0 Size:	116.2 KB ID:	890911 Click image for larger version  Name:	fixed1r.jpg Views:	0 Size:	183.4 KB ID:	890912 Click image for larger version  Name:	Fixed2r.jpg Views:	0 Size:	121.4 KB ID:	890913
                          • 8893
                          Many times the exhaust header gaskets can be re-used, but not always. Probably a good idea to change them while it's off. The new gaskets can be held into the head while assembling with a few dabs of grease.
                          Yes, the factory exhaust is a bit of a pain to remove/install, mostly because of the weight of it.
                          https://www.amazon.com/CALTRIC-Exhaust-Muffler-Gaskets-1978-1981/dp/B01N51W95R/ref=sr_1_1_sspa?crid=2LFYQSMF90XB4&dib=eyJ2IjoiMSJ 9.TEGBA1aaM_DG-ilEGoKJR0Li7O1dSE7f6kSa1mg0cYd7w6kOC3EOOQifOLaq6lJ YlIbP07zE1p6QsFc3ZKFw-AvSBZoiVqDdjALNYHDnIV81alZqpaiXtz2tmHxgtdjTuLJi-7PbrxvHq4q2ty8rWNnyyZFqMrJlDLb6OMwfPt1suCoGZJxeWw3 Hx-HeOUGAjNNCIys__ITvBZHGSSDps9lmuPN6tIEWDGA0EclQ1gUS hywTmJK4fcUAlqfAmUTnSbMxHAueAgTPZVZ4cD88yU8PEd1F9U rKOScO-HES4hI.gYF1YyEtdhgvFOGgm7IXrFjQXQ8UHufdVwpuXz5QtZw &dib_tag=se&keywords=xs1100+exhaust+gaskets&qid =17 84652299&sprefix=xs1100+exhaust+gaskets%2Caps%2C29 4&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
                          • speedlimit85
                            • Jan 2017
                            • 448
                            • Gainesville, Fl.
                            He's gonna weld it on the bike. I just stopped at the shop. He welded the other side with good results. I thanked him for changing tires and brakes in time to ride back from the everglades in 7 hours. His eyes popped out of his head "on that thing?"
                            80 G
                              • 8893
                              Yep, people sure underestimate what these bikes are capable of. That's good news that the exhaust can be welded right there on the bike.
