exaust cracked
  • exaust cracked
    Maybe I take too many bumpy back roads. It's not too rusty, but today I heard rattling and there is a big crack through the right side just in front of the cross over.
    Can this be repaired, welded, JB? Could be hard to replace. I rode aroundy with it like that today, It's not dangerous yet right?
    80 G
ID:	865330 Click image for larger version
    80 G
      Trying jb weld exhaust...
      80 G
        They rust from the inside, so you are probably close to "end of life" on the factory system. The JB may give you another year or two, so it's a good first try. If you know how to weld, or have a GOOD local welder, that could give you about four more years.
          Speedlimit,, tack weld in four locations with a wire-feed welderl while exhaust is in place. Remove right side exhaust and finish welding break preferably using a torch and welding rod. Torch welding this spreads the heat across pipe while welding. Grind it smooth with an angle head grinder using a flap sanding disc. Paint the area using a can of Dupli-Colors High Temp Silver. That fix will last rest of bikes life. Just a tried and true procedure from a certified welder/fabricator.
            BTW, Dupli-Color brand spray paints are primarily located at your local NAPA dealers. It is also a high quality paint brand that stays looking good for many years!
              I agree. Go right to a good weld shop. Do not use any epoxy as it will contaminate any weld repair.
              1979 XS1100 Special
              1980 XS1100 Std parts bucket
              1987 ZL1000 Eliminator
                I had this happen on my original to me MNS. I took the bike to a reputable welder so that he could spot weld it to hold it together. I then took the exhaust off the bike and brought it back to him to finish the job. It would be best if you can find someone that can do TIG.
                  better Click image for larger version
                  80 G
                    Hit it with a brush to clean off the oxidation and put a bit of high temp paint on it to keep it from rusting out in the heat affected zones of the weld.
                    1979 XS1100 Special
