"Shall We, Play... A... Game...?
  • XS-play
    • Nov 2013
    • 109
    • Austin, Tx.
    Okay I just thought I would have a little fun, here.
    I have several bits and pieces that I have collected for my Long Over Due XS build. Many of them, I know what and where they go. Some not so much.
    I thought it might be fun to see if someone can ID the parts, the more the merrier. Sorry there are no prizes, cept-n-for bragging rights, maybe. I have a few that I am curious what they are, or if they are even XS related. There is one Easter Egg of sorts, it is for an XS but not factory.
    Here ya go, Game Board ONE
    and Game Board TWO
    This image is just for information, a question. There is a subtle difference between the two on the right, the wire Bails are different. I am assuming these two were for the Specials I can't imagine there being more than one version required. Can anyone expound on these?
    80 SG
    81 Midnight Special (R.I.P.)
    • 7654
    A-2, first board looks like the egg! I'll need to look at the rest tonight, as I'm trying to get my XS to NOT leak gas from the tank/petcocks today.
    • newc4
      • 605
      • Vienna VA
      I’ll play
      Board #2
      A1 – kickstand cover & retaining screw
      A2 – fork top air caps
      A3 – Oil filler screw. Left those in the parking lot on several occasions
      A4 – brake bleed screws
      B2-4 – carb boot retainer bands
      C2- throttle cable attachment point
      C5 – airbox bracket
      Darrell
      78E
      80G project
      06FJR
        • 1988
        I think A2 in the first picture is a bolt that holds a rotor on the wheel.
        I think the "egg" is B1 in the second picture. This item looks like a homemade patch to put over the petcock holes when you are cleaning the gas tank.
        I'll let other members identify the remaining parts.
          • 8697
          Board 2, C4 are rear master cylinder push rods.
          Board 1, D4 are countershaft washers as in the second gear washer move.
          Board 1, C1 is the Standard headlight coarse vertical beam adjuster.
          • MarkD
            • Jun 2013
            • 488
            • N. Michigan
            D-2 board 1 = seatpan rubber pads/washers.
            79 F
            1967 Suzuki X6 Hustler
            1973 Suzuki TM 125
            1979 XS1100 F
            2005 Kaw. Vulcan VN800
            1991 BMW K75
            • XS-play
              • Nov 2013
              • 109
              • Austin, Tx.
              Board 1 A2, is one of the unknown parts for me, not even sure if this belongs with an XS. It is too big to be a rotor bolt, though.
              Ding Ding Ding Ding.... Winner Winner Chicken Dinner. Wow I am impressed. Bravo Zulu, RadioGuy
              80 SG
              • XS-play
                • Nov 2013
                • 109
                • Austin, Tx.
                Yes, I was just looking for stuff to powder coat one evening, All the Red is from that run.
                I will take your word for the Counter Washers.
                Board 1: I am not sure about C1 you could be correct, I have no clue about Board 2 C1 either. Board 2 C2 is the Headlight Bucket Brace, for the special, yes?
                80 SG
                • XS-play
                  • Nov 2013
                  • 109
                  • Austin, Tx.
                  Originally posted by newc4
                  I’ll play
                  Board #2
                  A1 – kickstand cover & retaining screw YES [kickstart]
                  A2 – fork top air caps YES
                  A3 – Oil filler screw. Left those in the parking lot on several occasions YES
                  A4 – brake bleed screws BANJO BOLTS
                  B2-4 – carb boot retainer bands YES
                  C2- throttle cable attachment point HEADLIGHT BRACKET
                  C5 – airbox bracket YES
                  Good Job, newc4
                  80 SG
                  • XS-play
                    • Nov 2013
                    • 109
                    • Austin, Tx.
                    I don't recall for certain, I think they are part of the Airbox Assembly.
                    80 SG
                    • XS-play
                      • Nov 2013
                      • 109
                      • Austin, Tx.
                      This is fun, keep 'em coming.
                      80 SG
                        • 8697
                        Yes, I believe it is.
                        • Bax
                          • 344
                          • Merrimack, NH
                          Bd-1, B3 = Right side air box mount bracket fitted washer.
                          Bd-1, D2 = Air Box mounting frame isolation pads
                          ---Bax
                          • Bax
                            • 344
                            • Merrimack, NH
                            Bd-2, C1 = Rear brake line holder.
                            ---Bax
                            • dpotter58
                              • Aug 2004
                              • 1843
                              • Southern Maryland
                              Board 2, b-5 washers for the battery box
                              1980 LG
                              1981 LH
