"Shall We, Play... A... Game...?
    OK, I'll go again. I DID get the egg first! This is all from memory, and I know some of this has already been done.
    Board 1
    A-1=? A-2=egg off a different bike A-3= hold down bolt for coils? A-4=? A-5=?
    B-1= tank hold down washer B-2= rear shock washer B-3=top left mount for airbox B-4= pointer for timming/TDC B-5=?
    C-1=headlamp adjuster C-2= cover for kick starter C-3=Fork caps C-4=? C-5= parts for airbox
    D-1=? D-2= straps for airbox D-4= washers for triple tree?
    Board 2
    A-1= cover and wingnut for kick start lever A-2= caps for later model forks A-3= oil fill cap A-4= banjo bolts for brakes A-5= ?
    B-1= ? B-2= carb/airbox clamps B-3= Carb/engine clamps B-4= carb/engine clamps? B-5= battery box parts
    C-1= rear brake line holder C-2=? C-3=fender to front brake line holder C-4= rear brake push rod C-5= Air box top bracket
    D-1= Special model holder for tank/frame cover
    Board 3
    B-1= wire holder, under the triple tree, Special model B-2&3 are Standard model wire holders
