1979 xs1100 11,775 miles
Going to be changing every fluid, filter, plugs, sync carbs, complete brake overhaul, tires (regrease shaft drive) fork oil etc... Bike is in pristine shape but want it perfect mechanically as well...
1.) When syncing carbs are people removing tank or is there enough room to access screws with tank on?
2.) easiest/best way to flush old oil (never had a bike with a drain before always had to remove forks!) I would typically dump old oil and fill with ATF and slosh/pump and dump to clean forks out aside from merely draining.
3.) I have a leak underneath but haven't had time since hauling it home to investigate. Doesn't seem to be from drain plugs So I was thinking maybe chain tensioner area (haven't had time to do anything but a quick look underneath.. If so can a sealant be applied or do I have to remove/replace gasket?
4.) are the plug wire integrated into the coils (my Road Stars are) and if not where could I get stock looking wires IF not available from Yamaha.
5.) getting automatic cam chain tensioner vs adjusting stock one. I viewed the procedure for adjusting cam chain tensioner and it doesn't seem to bad. How often does this need to be done usually? I wouldn't mind putting an automatic one from a Vmax on and then setting it once and forget about it either. I don't plan on putting more than 1500 miles a year on this bike honestly and didn't know if it's worth swapping out the stock one to an automatic one.
