Crankcase question
  • FJ111200
    • Oct 2007
    • 317
    • Crewe, Cheshire, UK
    Originally posted by HazXS
    What is the idea of having nozzles and why not just have machined holes? Just a thought
    Exactly. Probably helps to pressurize the oil into more of a jet to help lubricate the bearing. But looking at it, i'd re-use that crankcase, though i'm not an engineer, and no doubt someone will be along to say why it would not be a good idea.
    • HazXS
      • Jan 2021
      • 15
      • Brighton, UK
      That makes sense, it would be nice to reuse it but no issue if I can't.
      Why do I have to touch things when I should just leave them alone!!!
      • FJ111200
        • Oct 2007
        • 317
        I've heard that crankcases are a machined pair and should be used as a matching pair and might leak oil if not used that way. Whenever i've rebuilt engines, and i've rebuilt 2 XS1100's and 3 FJ's, i've always used the matching pairs.
        Good news is that the nozzles are still available to buy new.
        • HazXS
          • Jan 2021
          • 15
          • Brighton, UK
          Just did a quick look up and got a mixture of both. I have drilled out the mushed nozzle and hoping if I tidy it up there shouldn't be a problem but what do I know .
          yea I see them on cmsnl
            • 7693
            The case looks usable to me. The bearings have a steel shell, so should not be a problem.
            The nozzle helps keep the oil pressure about the same though all the bearings. The three smaller holes also keeps it from pushing too much oil, and possibly causing a spun bearing.
            • HazXS
              • Jan 2021
              • 15
              • Brighton, UK
              Ah ha thank you for the info Ray. I shall tidy the area up and guess helicoil it. What are you thoughts on what XSive said that there is a possibility case's are of one cast. Curiosity always prevales.
                • 7693
                Yes, the cases are machined as a pair. If you were to use a different bottom case, you would need to have the cases line bored on ALL the shaft locations, transmission as well as the crank.
                • Bax
                  • 344
                  • Merrimack, NH
                  HazXS, I'd give that case a go for new nozzle and reassembly. A big must = flush out the oil passages of the drilling waste...................
                  ---Bax
                  • HazXS
                    • Jan 2021
                    • 15
                    • Brighton, UK
                    That settles it really. I will use the original case and I will keep updating on the progress of this bike. Its a slow burner but a truly wonderful bike.
                    • HazXS
                      • Jan 2021
                      • 15
                      • Brighton, UK
                      Not the end of the thread but thank you all so far in taking the time to respond.
                      • FJ111200
                        • Oct 2007
                        • 317
                        No problem mate. Got to keep these old XS's alive and kicking. BTW, if you haven't already been notified, you are now the latest member of XS1100UK Club forum.
                        • HazXS
                          • Jan 2021
                          • 15
                          • Brighton, UK
                          Ah finally! Yea they are a nice bike. I'm going to put wiseco 1179 pistons. Got 2 and now getting the other 2 next month. Got new crank and conrod bearing coming by the end of the month. Not sure if people are interested in progress and parts but can do a feed if that's a thing. This is all new to me. Though????
                          • FJ111200
                            • Oct 2007
                            • 317
                            What i would do if it hasn't already been done is to do the 2nd gear washer swap Find the info here Addendum(s) to 1st/2nd gear tranny fix - XS11.club Forums I've done it on 3 engines even if it's just a precaution because some engines don't have a gearbox problem and some do and it's better to do it while the engine is apart than find out after it's all back together. Just my two penneth worth.
                            • HazXS
                              • Jan 2021
                              • 15
                              • Brighton, UK
                              Thanks for the info yea I have heard about this issue. I have a weekend of sorting parts out so I will look into it this Saturday. This issue seems to be hereditary throughout other models of yamaha
