Need new intake manifold rubbers
  • cnap504
    • Dec 2020
    • 56
    • Louisiana
    Hello everyone, thanks for having me, first post for me here.
    I’ve been riding for more than 50yrs and have just gotten a 1980 XS1100 Special in pretty rough shape. I pulled the carbs and I can easily see the intake boots are shot. Any recommendations on replacements or tips on known bad parts? This bike is going to need a lot of TLC (yes a lot) and money too so if I can get reasonably priced good parts it’ll help. Thanks
    • 7769
    I bought replacements at partsnmore.com maybe 15 years ago. They're still like new. A quick search didn't turn them up. Good price here: YAMAHA XS1100 SPECIAL XJ1100 INTAKE CARB HOLDERS
    • 2WheelFun
      • Aug 2020
      • 266
      • Pittsburgh PA
      https://www.amazon.com/gp/aw/d/B07XD...ie=UTF8&psc=1#
      Only 3 out of 4 fit. This one is a no go.
      1979 XS1100 Special
      1980 XS1100 Std parts bucket
      1987 ZL1000 Eliminator
        • 3206
        Welcome! Are the boots cracked all the way through? Many times it’s simply exterior cracks but they don’t make it all the way through. If yes, clean off the exterior and get a spray can of Plasti-dip, build up layers to where they have a much better appearance and it will ward off further cracking. Worked great for me, and others have done this as well.
        ZRX1200
          • 1798
          I purchased these and they work fine. They are from Japan. 79-81 YAMAHA XS1100 CARB INTAKE MANIFOLD SET INSULATOR 4 INTAKES CI-XS1100INBT | eBay
          • cnap504
            • Dec 2020
            • 56
            • Louisiana
            Ordinarily I would try your suggestion but the carbs are off for a cleaning and rebuild. The rubbers are hard and fractured almost all over. Figured it would be a good time to replace them.
            How do i I list my bikes at the bottom of my posts like I see so many of you have done? Thanks
              • 3206
              Yeah, mine were cracked everywhere as well however they didn't go through all the way so it was a good fix. Rubbers were hard, however they still functioned fine.
              ZRX1200
                • 1798
                Click on your profile name then click on edit settings then account tab at the top. About middle way down you will see Edit Signature.
                  • 3206
                  Thx Cajun31 for that info.
                  ZRX1200
                  • Forden
                    • Apr 2022
                    • 81
                    • Ipswich, MA
                    cajun31 how are these holding up with time? I'm about to order a set. Prices are all over the place, I'm avoiding ones from China but these (from Cruznimage) look a good deal.
                    1978 Suzuki GS750E
                      • 7769
                      Tourmaster is the same as OE. They're marked ARS on the outer lip.
                      I believe these are the ones: https://www.georgefixs.com/xs1100-xj1100-j-intake-carb-boots-holders-and-gaskets/
                        • 8641
ID:	868526 I like the Tour Max brand, heavy duty, 100 bucks. On the Cheapo 25 dollar ones, the vacuum ports become loose after a few heat cycles. The rubber becomes Click image for larger version  Name:	IMG_20220425_220417.jpg Views:	0 Size:	174.5 KB ID:	868525 soft and flimsy when they get hot. I won't ever buy the cheap ones again.
                          • 1798
                          I modified them before I put them on. I heated them up enough to get the rubber flexible and then pulled the vacuum tubes out. I then scored the brass to give the epoxy something to grip to as well as the holes left in the manifolds. The reason was because we had this discussion once before concerning the lower cost manifolds. Even though these are indeed from Japan, I went the extra step to ensure the tubes don't leak or come out. I have had some of the Chinese ones fail while tuning the bike. The Octy tube on number two was so tight on the vacuum brass that when I pulled on it with my needle nose the tube came right out of the manifold. Needless to say I wasn't a happy camper. i had to pull the carbs and the manifolds and repair them. The ones from Japan are reinforced internally like the originals.
                            • 7769
                            Yeah. That's what I meant.
                              • 8641
                              Yep Marty, I had to Google Tourmaster, at first I thought it was golf equipment, but it's actually motorcycle riding apparel.
                              Jim, the way I kept the vaccum tubes from pulling out is by using a thread die on them and then pressing them back in with some silicone sealer.
                              I also developed a strange issue with the Cheapo boots. They would develop a vacuum leak when they reached a certain temperature. After 30 minutes of riding, the idle speed would increase about 300 RPM more than usual. It unbelievable how flimsy they become when super hot. They may work just fine up in Canada.
