carb specs
    • 7766
    What about a Dove load? Let the bike know it needs to fight?!
    • RiskyBusiness
      • Mar 2003
      • 174
      • Richmond, Virginia, USA
      Well since you bring it up...
      OO buck is actually .33 inch (8.38mm) and what we need is .125 which is right between #4 and #5 bird shot. The good news is that #4 and #5 both come in steel (clearly better than lead for this application) Buy a box of each and open a shell and give it a whirl. Be sure and let us know how it goes!
      -RB
      Here's a shot size guide for quick ref.
      1979 XS1100 Special with 81 carbs
      • rover
        • Jan 2004
        • 765
        • central WI (715)
        BOOM
        79 F (Blueballs)
        79 SF (Redbutt)
        81 LH (organ donor)
        76 CB 750 (gone to MC heaven)
        rover has spoken
        • randy
          • Dec 2003
          • 4521
          Geez, just go get a 1/8" ball bearing!
          Mcmaster has 'em:
          9528K11
          E52100 Alloy Steel Ball 1/8" Diameter, Grade 25
          In stock at $2.64 per Pack
          This item is only sold in Packs of 100
          McMaster.com
          • fxrer
            • Aug 2004
            • 241
            • Bethlehem, PA 18017
            Go to the thread on 6-24-05, titled
            "81 Special Choke detent", started by btdtdan.
            In addition to my suggestion to use a key chain ball, pggg had this to offer:
            "If you want an IMPROVED choke - don't worry about the BB's. Just place a brass(self lubricating) washer on the lever. Gives a fully adjustable choke range - you're not stuck with just two positions."
            here is a picture:
            http://homepages.inspire.net.nz/~patrick/leverr.jpg
            Rick
            '80 SG
            '88 FXR
            '66 Spitfire MK II
            • xswilly
              • Jul 2003
              • 462
              • Hollis, maine
              ok guys
              i bought a pkg of 1/8 ball bearings
              pkg of 100 smallest i could get for 2.68
              I'm set for life now
              it was for #4 carb, i lost the ball bearing, i saw it fall
              well tonight i assembled my carbs and put them back on the rack
              only to find that the only ball bearing that has a detent on the choke rod is on the #1 carb, seems the one on the #4 carb doesn't do anything
              at least as far as i can see
              http://home.securespeed.us/~xswilly/
              78E main ride, since birth the "good"
              78E Parts, the "bad" fixing up now
              78E Parts the "ugly" maybe next year
              79F Parts
              80G Parts
              75 DT 400B enduro
                Hey Willy,
                I think the ball bearing in #4 helps keep the pressure against the choke rod even across the length of the rod.
                So...you're going to be OUR NEW carb ball distributor?!
                Shall we put your username in a LINK message as a source?!
