carb specs
  • xswilly
    • Jul 2003
    • 462
    • Hollis, maine
    carb specs
    anyone out there know the diameter of the detent balls
    on the choke shaft, i lost one on my 78E
    http://home.securespeed.us/~xswilly/
    78E main ride, since birth the "good"
    78E Parts, the "bad" fixing up now
    78E Parts the "ugly" maybe next year
    79F Parts
    80G Parts
    75 DT 400B enduro
    Big Balls!
    Hey there XSwilly,
    Just measured it with my digital caliper, it's 3.15mm or 0.124",
    hope this helps!?
    PS, I've gotten my magnetic holder for my new machinists dial indicator 1" range. 001" sensitivity! I've ordered my quick change tool post, so I should be able to actually start practicing some lathing soon!!
    • xswilly
      • Jul 2003
      • 462
      • Hollis, maine
      I took apart a spare set of carbs i had
      they came from a bike that was sitting outside for 5 years
      the motor was siezed.
      and up here in maine with the huge difference in temps from summer to winter, sitting outside does alot of harm.
      they were very nasty
      at work we just got an ultrasonic cleaner, its a small one about 8 inches x 8 inches, so i took 1 carb off of the rack and brought it in to see how good it would clean it,
      all i did was remove the diaphram and the float, and bowl
      it did a great job, very clean, the only thing it didn't take off was the oxidation on the outside of the carb
      so i'm anxous to try the other 3 carbs
      and put them on a bike to try them
      79F Parts
      80G Parts
      75 DT 400B enduro
      • RiskyBusiness
        • Mar 2003
        • 174
        • Richmond, Virginia, USA
        Willy,
        I don't know Jack about ultrasonic cleaners so I googled it after reading your post. I have seen these in my dentist's office but didn't know what they were. Some of them use just water inside and some use a solution of some sort. What did you use inside?
        -RB
        1979 XS1100 Special with 81 carbs
        • randy
          • Dec 2003
          • 4521
          Detent Ball
          Willy, In case you can't find one in mm, my parts fiche shows it as 1/8 inch:
          70 93501-08001-00 BALL (1/8 INCH)
            Hey Randy,
            Isn't 1/8" = 0.125".....about what I had said earlier at 0.124"?
            I figure he being a machinist knew that!
            • randy
              • Dec 2003
              • 4521
              Right, T.C.
              Same size, just figured he might need the conversion?
                You had better go esy on that detent ball TC! You are wearing it out with the caliper! :-)
                Hey Randy,
                • xswilly
                  • Jul 2003
                  • 462
                  • Hollis, maine
                  thanks for the info guys
                  i used a additive that came with the ultrasonic cleaner
                  just a general use cleaner
                  79F Parts
                  80G Parts
                  75 DT 400B enduro
                  • wfold
                    • Sep 2005
                    • 6
                    Be careful with parts and ultrasonic cleaners. If your not and they are in for too long or have weaks spots you can really get some nasty pitting. Machined parts should be okay in it but I wouldn't put anything cast in. If the part is not too intricate brasso and a small piece of a rough cloth (emery etc.) can work charms.
                    • fxrer
                      • Aug 2004
                      • 241
                      • Bethlehem, PA 18017
                      I used two of the little balls from a key chain - they work fine.
                      Rick
                      '80 SG
                      '88 FXR
                      '66 Spitfire MK II
                      • rover
                        • Jan 2004
                        • 765
                        • central WI (715)
                        BB gun BB's
                        79 F (Blueballs)
                        79 SF (Redbutt)
                        81 LH (organ donor)
                        76 CB 750 (gone to MC heaven)
                        rover has spoken
                        • rover
                          • Jan 2004
                          • 765
                          • central WI (715)
                          OOPS, BB gun BB's are .177, might be too big. I used them on A carb, not sure which one.
                          79 F (Blueballs)
                          79 SF (Redbutt)
                          81 LH (organ donor)
                          rover has spoken
                            Maybe steel buckshot? It would let the carbs know that you mean BUSINESS!
                            • rover
                              • Jan 2004
                              • 765
                              • central WI (715)
                              O-O Buckshot only comes in lead, and they are 22 caliber.
                              79 F (Blueballs)
                              79 SF (Redbutt)
                              81 LH (organ donor)
                              rover has spoken
