Who owns the fastest XS11?
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    #226
    I Own It Now!
    I'm not that crazy to take this thing to the limit... I figure the blue streak will easily do 150 maybe 160....no joke....I changed the final gear ratio, and she pulls just as hard at 110mph as she does at 80 mph...SICK!
    MDRNF
    79F.....Not Stock
    • pggg
      • 1609
      • NZ
      #227
      A higher gear ratio won't increase top speed without downhill/tailwind assistance, as actually the stock XS11 gearing gives the most power in 5th gear. The designers were clued up and cunning! Chop, open her right out in 5th and you'll find at around 120 mph the real struggle begins
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        #228
        sorry to bust your bubble
        The thing is pulling just as hard in 5th gear with the new gears. The stock final gear ratio is 3.3, my new gearing is 2.9....4th gear now feels like old 5th.... driving home from work at 70mph, the rpm is noticeably lower....
        MDRNF
        79F.....Not Stock
        • knewsom
          • Apr 2006
          • 378
          • San Diego, CA
          #229
          ...so you plan on sharing the how-to's of this this marvellous modification with the rest of us schmoes?
          To me, it stands to reason that if you can boost the horsepower of the engine AND modify your final drive gear ratio, you should be able to get quite a bit more top end, and probably more fuel efficiency as well.
          ...I'd sure love to cruise at 70mph at 3k RPM...
          Kristoffer
          "Take apart yer carbs!"
          1978 XS1100E - "The Maroon Baboon" (SOLD)
          1979 XS1100 (3 of them) in the garage. Not deserving of names yet.
          • pggg
            • 1609
            • NZ
            #230
            Chop, stock gearing in 5th is 15.5 mph per 1000 revs, mine's set up at 17.5 mph per 1000. I did try a few other ratios(taller) but the 17.5 mph per 1000 is the one I like best. Sounds like your XV ratio could be similar.
            • pggg
              • 1609
              • NZ
              #231
              It's bizarre the motor pulls like a f*** train even with waay tall gears, mine was doing 110 kph in 1st and 2nd good for 90 mph but gets there just as quick as the normal gears. 3rd is an easy ton, 4th arm-wrenching forward after that and just as fast as 5th gear usually(top speed) 3000revs @ 100 kph was that same ratio and that's the max limit you'd use on the road bike. 140 mph was quickest I done on that gear. Down a hill or with hotter cams or a few other tweaks 150mph for sure if you're game. Nitrous would be off the planet on an XS11, if 3rd,4th and 5th gears could handle it. Gearbox needs beefing up inside for 1st and 2nd.
              • xschop
                • Feb 2006
                • 1794
                • oklahoma city
                #232
                Mph/1k
                Hey pggg, according to your stock gearing figures, I am now doing 17.7 mph/ 1K revs. The final drive gear ratio now is definitely 2.90/1 and the XS11 is 3.3/1 when I rotated to make sure. The final gear box is not from an XV, I went another route and installed new gears to the 11's drive hub I figure a 65 mph, I am revving @3600 RPM. This is awesome because because the passing gear is outlandish. you can either hit the throttle and wait for the G to kick in, or drop to forth and you better not be week in the wrists....
                MDRNF
                79F.....Not Stock
                • mro
                  • 4276
                  • Hayward, California
                  #233
                  Nitrous???
                  new set of flat sides I'm playing with are set up for adding it
                  mro
                  • xschop
                    • Feb 2006
                    • 1794
                    • oklahoma city
                    #234
                    light weight
                    Remember, the Blue Streak is about 70 lbs lighter than when I got her. I don't even have a center stand, not to mention that heavy setup of a stock rear fender/light combo or that monster 10 lb seat! probably lost another 5 lbs from the headlight/gauges....I hope the gsxr carbs will really add another 25 horses, if so I won't be needing to do the big bore on the Streak, but who knows...
                    MDRNF
                    79F.....Not Stock
                    • Shuriken
                      • 1093
                      • Southwest USA
                      #235
                      You guys are sick and you badly need help.
                      But you are doing great things with the XS11, so don't see a doctor...
                      I'm still waiting for someone to sell a complete fuel injection package with instructions.
                      Ben
                      Formerly:
                      1982 XS650
                      1980 XS1100g
                      1979 XS1100sf
                      1978 XS1100e donor
                      • posthuman
                        • 71
                        #236
                        No way Id' get past 95 or so, because intense high frequency engine vibration around 7k makes me worry, like it going to vibrate itself apart.
                        I presume this is because of poor carb tuning/valve spacing
                        (or is this normal?)
                        XJ 1100
                        XJ 550
                        • knewsom
                          • Apr 2006
                          • 378
                          • San Diego, CA
                          #237
                          agreed. If I had a 6th gear, I'd consider taking it above 100.
                          Kristoffer
                          • Pat Kelly
                            • 3046
                            • Golden Valley, AZ
                            #238
                            My XS1100 is the fastest XS1100 at my house..... both of them (the E is faster and quicker that the LG). SWMOB's XV1100 dosen't stand a chance but is a nice bike too.
                            Pat Kelly
                            <p-lkelly@sbcglobal.net>
                            1978 XS1100E (The Force)
                            1980 XS1100LG (The Dark Side)
                            1999 Suburban (The Ship)
                            1994 Dodge Spirit (Son #1)
                            1968 F100 (Valentine)
                            • pggg
                              • 1609
                              • NZ
                              #239
                              Intense high frequency engine vibration must mean there's something wrong there, some of the engine mount bolts might have stripped threads or something, combined with unbalanced carbs and other stuff, may be the shaftdrive or wheel bearings.
                              • REFFI
                                • 280
                                • Orange County, California 92626
                                #240
                                I ran my '80G over 100 a few times and did not notice any untoward vibration / noise. Maybe it's the road surface?
                                Ralph
