Misfiring
  • Phare Est
    • Aug 2016
    • 70
    • Church Point, Nova Scotia, Canada
    #76
    Not the field coil wires but pickup coil wire harness that runs under the rear of engine.
    Thanks bikerphil. I’m not sure I’ve even seen that wire harness, but I’ll have another look.
    '81 XS11LH
    '07 Kawasaki VN2000A
      • 5073
      #77
      See posts 60 and 62.
        • 3373
        I have a big bowl of popcorn all buttered up and salted, sitting here waiting until the show starts. Is the main feature going to be electrical or are the carbs going to steal the show?
        2001 ZRX 1200
        1982 Seca 750
        1983 Nighthawk 550
        • CaptonZap
          • Jun 2010
          • 1748
          • Denver
          #79
          What kind of oil did you say you wanted on your popcorn?
          • Phare Est
            • Aug 2016
            • 70
            #80
            Hi skids,
            Thanks for the tips! I may indeed have to do more rewiring on the bike. I was able to resolve a couple of electrical issues last year by replacing some old wires.
            '81 XS11LH
              • 5073
              #81
              If I remember correctly, you said problems started after washing the bike. This is a common issue with missing ignition, but usually only when not in neutral (in gear) and Scott Compton said the splice in the loom above the left side cover is the culprit. Good luck with tracking down the problem whatever it is.
                • 3373
                Movie theater butter, please!
                2001 ZRX 1200
                1982 Seca 750
                1983 Nighthawk 550
                  I believe that splice is below the left engine side (case) cover. Not to be confused with the plastic cover on the side of the bike.
                    • 3373
                    I could understand that if the bike was still wet. It's long dried probably.
                    I'm still thinking maybe a float bowl gasket is impeding a float (s). That's one thing he said that he put new float bowl gaskets on the carbs.
                    2001 ZRX 1200
                    1982 Seca 750
                    1983 Nighthawk 550
                    • Phare Est
                      • Aug 2016
                      • 70
                      #85
                      I checked that wire harness (which was neatly tucked in between the engine and the frame) and there does seem to be a break in it (I'll have to pull it out further to make sure). Some exposed wires could have been touching the frame... If this turns out to be is the case, I'll replace the wires this weekend and keep you all updated.
                      '81 XS11LH
                      • DAVINCI
                        • Jan 2011
                        • 1048
                        • Cedar Mountain, NC
                        #86
                        that harness will also get fouled by water
                        • Phare Est
                          • Aug 2016
                          • 70
                          #87
                          Success
                          I pulled out that wire harness coming out of the pick-up coil and found that it was cracked in one spot because it had been sitting too close to the exhaust. Three of the five wires were exposed. I replaced all five wires using crimp connectors and made a new harness with shrink tubing. I felt certain I had found the culprit, but to my amazement, the engine was still very difficult to start and kept misfiring...
                          I went ahead and swapped the existing ignition switch with a new one I received earlier this month (https://fortnine.ca/en/emgo-ignition-switch-40-71340). Holding my breath, I pressed the start button: the bike fired up immediately and all cylinders were working oh so smoothly. It's now running like a champ again!
                          Thanks a million to everyone for the help along the way!
                          '81 XS11LH
                            Good to hear you've had success! May wanna put that original ign. switch in a cup of evaporust overnite. After which wash it all out with hot water and blow it out using an air-hose. Keep for an extra ign. switch.
                              • 3373
                              So the carbs were having an electrical problem! Kind of... LOL.
                              Really happy you found the problem! Good work and perseverance.
                              2001 ZRX 1200
                              1982 Seca 750
                              1983 Nighthawk 550
