Misfiring
    Yeah, that's the "octy". Most people bypass and discard it, as it makes it easier to run the fuel lines. It's only reason for being on the bike is to shut off the fuel when the engine is not running. The problem most have with it is the number of fuel lines causes crimps in the lines when putting the tank on, and the bike will not reach full power due to fuel starving.
    do a search on "octy bypass"
    • Phare Est
      • Aug 2016
      • 70
      • Church Point, Nova Scotia, Canada
      Precisely what I was thinking! Too many fuel lines under that tank. Is it necessary to use non-vacuum petcocks to bypass the "octy"?
      '81 XS11LH
      '07 Kawasaki VN2000A
        As I understand it, you lose the automatic fuel flow. The petcocks will need to be turned on and off manually. This would be no big deal breaker to me! My old honda 350XL was like that and you get used to it. That octopus thing was designed by someone on drugs! The standards are nothing like that!
          The special has non-vacuum petcocks, hence the octy. Here is what I wrote a while ago to someone else about bypassing the octy.:http://www.xs11.com/forum/showthread...octy+bypass%22
          Remember to put a cap on the #2 intake boot, as you no longer need it for the octy.
          • Phare Est
            • Aug 2016
            • 70
            #35
            New coils
            I just received the "new" coils taken off a Maxim 1100. I tested them with the ohmmeter and they both seem to be good, although I haven't installed them on the bike yet. I'll keep everyone updated.
            '81 XS11LH
              • 3372
              Nice work on figuring out they might be the problem, I hope they work! You sure are “on an island” up there!
              You would be in the running and probably a shoe-in winner of the golden drain plug at the Colorado rally this summer. July 11-15 in Durango. It is awarded at my discretion for people who come a long way to the rally, deflect deer off their FJR with no damage and duck airborne Kerker baffles launched from the guy in front under hard acceleration. Russ was the inaugural winner last year for two of those three being attained.
              2001 ZRX 1200
              1982 Seca 750
              1983 Nighthawk 550
                • 2117
                I replaced my octy with a Pingel fuel valve and that works great and also run fuel filters which greatly help.I think to remove my carbs, I disconnect 2 fuel lines.
                  • 3372
                  Is it the stock petcocks feeding down to a pingel valve and then on to the carburetors?
                  2001 ZRX 1200
                  1982 Seca 750
                  1983 Nighthawk 550
                    • 2117
                    I actually have Pingel petcocks on my bike and have the original petcocks in my apartment.I only had to have 1 Pingel petcock rebuilt by them in the whole time they been on the bike-maybe 20 years.
                      • 3372
                      Gotcha, so each side feeds 2 carbs.
                      2001 ZRX 1200
                      1982 Seca 750
                      1983 Nighthawk 550
                        • 2117
                        Yes I did some other plumbing work but it is set-up real nice
                          • 3372
                          Good work.
                          2001 ZRX 1200
                          1982 Seca 750
                          1983 Nighthawk 550
                            • 2117
                            Bonz-I see you have a ZRX 1200-I have a 99 ZRX 1100.
                              • 3372
                              Yes, I'm pretty active over on the zrxoa forum. Have you ever joined up there?
                              I've done a lot to the bike. Running ZZR 1200 cams, ZX11/ZZR1200 CVK40 carbs, pods, double valve springs, ZX11 ECU that raises the rev limit to 11,500, JE high-compression pistons, Muzzy full system, custom valved and sprung stock KYB shocks, Sonic springs up-front, GSXR front calipers, lots weight reduction elsewhere.
                              There are times I wish I hadn't sold my pair of pristine 80SG,'s but they really weren't comfortable for me anymore with the knee bend given my height and leg length.
                              2001 ZRX 1200
                              1982 Seca 750
                              1983 Nighthawk 550
                                • 2117
                                Yes I been a member since 2006? I just got done replacing a throttle cable and cleaning the carbs on mine. I was thinking about selling it as I didn't ride it much after an accident in 2012 but the place where I go wont give me much money but he will sell it for way more. I will ride it more often now so it doesn't sit.
