Misfiring
If I remember correctly, you said problems started after washing the bike. This is a common issue with missing ignition, but usually only when not in neutral (in gear) and Scott Compton said the splice in the loom above the left side cover is the culprit. Good luck with tracking down the problem whatever it is.Skids (Sid Hansen)
I believe that splice is below the left engine side (case) cover. Not to be confused with the plastic cover on the side of the bike.If I remember correctly, you said problems started after washing the bike. This is a common issue with missing ignition, but usually only when not in neutral (in gear) and Scott Compton said the splice in the loom above the left side cover is the culprit. Good luck with tracking down the problem whatever it is.Marty (in Mississippi)
XS650EComment
I could understand that if the bike was still wet. It's long dried probably.
I'm still thinking maybe a float bowl gasket is impeding a float (s). That's one thing he said that he put new float bowl gaskets on the carbs.Howard
ZRX1200
Seca 750Comment
I checked that wire harness (which was neatly tucked in between the engine and the frame) and there does seem to be a break in it (I'll have to pull it out further to make sure). Some exposed wires could have been touching the frame... If this turns out to be is the case, I'll replace the wires this weekend and keep you all updated.'81 XS11LH
'07 Kawasaki VN2000AComment
that harness will also get fouled by waterI checked that wire harness (which was neatly tucked in between the engine and the frame) and there does seem to be a break in it (I'll have to pull it out further to make sure). Some exposed wires could have been touching the frame... If this turns out to be is the case, I'll replace the wires this weekend and keep you all updated.Former owner, but I have NO PARTS LEFT!
Success
I pulled out that wire harness coming out of the pick-up coil and found that it was cracked in one spot because it had been sitting too close to the exhaust. Three of the five wires were exposed. I replaced all five wires using crimp connectors and made a new harness with shrink tubing. I felt certain I had found the culprit, but to my amazement, the engine was still very difficult to start and kept misfiring...
I went ahead and swapped the existing ignition switch with a new one I received earlier this month (https://fortnine.ca/en/emgo-ignition-switch-40-71340). Holding my breath, I pressed the start button: the bike fired up immediately and all cylinders were working oh so smoothly. It's now running like a champ again!
Thanks a million to everyone for the help along the way!'81 XS11LH
Good to hear you've had success! May wanna put that original ign. switch in a cup of evaporust overnite. After which wash it all out with hot water and blow it out using an air-hoseI pulled out that wire harness coming out of the pick-up coil and found that it was cracked in one spot because it had been sitting too close to the exhaust. Three of the five wires were exposed. I replaced all five wires using crimp connectors and made a new harness with shrink tubing. I felt certain I had found the culprit, but to my amazement, the engine was still very difficult to start and kept misfiring...
. Keep for an extra ign. switch.
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
