Voltage Drop at Idle
    I'll agree to that !
    Still leaves me questioning my use of it when everyone disapproves of it's use but me ?
    If you would not buy a bike with dielectric grease used on it's electrical connections, I certainly will not tell you that I used it on the bike };-)
    Say is 4-5 PM a good time call to catch you free and easy ?
    Dielectric grease works alright for connectors and terminals if you're careful with it, my new bike has some connectors that are totally packed with the stuff and the lights still work. I bought a tube of Dow's finest space shuttle grease but it's messy, it attracts dirt, and there's no safe solvent for silicone to get it off of and out of places it's not supposed to be.
    Krytox grease works for drive splines but its solvent is expensive and not good for children and other living things.
    For battery terminals and grounds, copper anti-seize is good. Anti-seize is messy but it's easier to spot smudges right away without waiting for them to gather dust and they clean up with soap and water instead of getting a home HazMat permit.
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      Stuff i never heard of before ?
      The wonders of modern chemistry !
      What about ptfe ? ? ?
      Ptfe sure keeps the doors swinging, the chain drives chain from rust, guns, my 1/2 bath fan, the big overhead fan and so much more.
      I digress, nuff said by me eh ?
      76 XS650 C ROADSTER
      80 XS650 G Special II
      https://ibb.co/album/icbGgF
      80 XS 1100 SG
      81 XS 1100LH/SH DARKHORSE
      https://tinyurl.com/k6nzvtw
      AKA; Don'e, UD, Unca Don'e
        Hi, Jack! (waving)
        Unless it's dry PTFE powder, the particles are mixed with an organic carrier base that can usually be removed with soap and water or a normal degreaser/solvent that takes the PTFE off along with the carrier.
        NASCAR uses that Krytox grease for u-joints and it dropped the running temperature and the wear way, way, down.
          You should ask MaximPhil about that. His brand new connector failed several hours from home. The new connector was filled with dielectric grease.
          Learned my lesson . took hours of cleaning to get rid of (most) of the damn dielectric grease. As already mentioned it attracts dust like crazy.
          Might be a place for it somewhere...but not on my bike.
          WD 40 and a small paint brush with paper towels. Then contact cleaner.
