Voltage Drop at Idle
    Anti-sieze I never heard of before on the grounds ? Is it as good, better than dielectric grease ?
    Please excuse me if I missed the mentioning of these things previously !
    I do use dielectric grease on things like battery terminals. I do not stuff it into clips, but I now use it around the perimeters of the plastic to keep moisture out. The problem with dielectric grease is that it attracts dust and makes a mess. It is also not a good electrical conductor. Once it has attracted dust (I live up 2 miles of dirt road) it is very difficult to clean out of the inside of clips if you stuff it in there. The use of antiseize to improve electrical connections is intriguing. I am sure that you would need to use it very strategically with light coating on electrical contacts or there could be some seeping and maybe some stray currents! I have not tried it yet.
      As an amateur radio operator I use "no-ox" on some connections. It's used to keep the electrons flowing, but it WILL conduct and cause shorts if misused. Anti-seize is a lot like no-ox, but MUCH cheaper.( HAM radio operators are cheapskates) You can usually find it in a hardware or auto parts store. It's also a good conductor, so I only use it on grounds to keep the possibility of shorts down.
      Dielectric grease is NON-CONDUCTIVE, so no electron flow past it. A small amount around connections keeps them clean and water out. I would NOT put it on the ground points, as it may cause problems because of the insulation properties.
        Dielectric grease is an insulator. Copper based anti-seize should conduct. Some disagree with me, but keep dielectric grease away from my bike. It might be good o’ring lube.
          Does make for an excellent o-ring lube.
          • donebysunday
            • Oct 2012
            • 1737
            • New Berlin, Wi.
            Dielectric grease
            Please correct me if I'm wrong !
            Isn't the idea of dielectric grease to insulate and not be conductive, in that way to keep the elements out and help prevent corrosion/oxidation ?
            76 XS650 C ROADSTER
            80 XS650 G Special II
            https://ibb.co/album/icbGgF
            80 XS 1100 SG
            81 XS 1100LH/SH DARKHORSE
            https://tinyurl.com/k6nzvtw
            AKA; Don'e, UD, Unca Don'e
              No, you aren’t wrong. My opinion is that it does more harm than good. It’s tough to get rid of as well. A little dab on the spark plug boot is what it’s for.
              • donebysunday
                • Oct 2012
                • 1737
                • New Berlin, Wi.
                Dielectric grease
                The first thing to do is remove the right side cover and the panel that the fuse box is mounted on. Behind it is the connector to the stator. Make sure that one is clean and conducting. Lose that one and it will take the stator with it. You'll know right away if it's bad. The plastic will be brown or melting.
                Hey Marty,
                In this post of a picture of the regulator plug that melted even with all that dielectric grease seen in the plug, is the dielectric grease culprit ?
                Or was the dielectric grease used after to try and compensate for a poor corroded/oxidized connection ?
                I've not had any problems with dielectric grease on bullet connectors or wiring plugs. Maybe it's how sparely I use the stuff ?
                As you said, My opinion is that it does more harm than good. It’s tough to get rid of as well. A little dab on the spark plug boot is what it’s for.
                Is it for the boot or the terminal of the spark plug ?
                76 XS650 C ROADSTER
                80 XS 1100 SG
                  It's for the boot of the plug. Helps keep water out, and keeps the boot from sticking to the plug.
                  Honda used it in the engine compartment of it's cars for years, from the factory. As stated, it will NOT fix a problem that already exists, but a LITTLE applied properly can keep the problems from arising.
                    Hey Marty,
                    You should ask MaximPhil about that. His brand new connector failed several hours from home. The new connector was filled with dielectric grease.
                    • donebysunday
                      • Oct 2012
                      • 1737
                      • New Berlin, Wi.
                      Dielectric grease
                      Veery interesting !
                      I've been using as I stated, on over 90 XS650s and XS1100 combined, no problem that I've in the last 30 years.
                      Now do I stop or keep using it wong, aaw so, what would Confucius ........ ?
                      76 XS650 C ROADSTER
                      80 XS 1100 SG
                        Veery interesting !
                        There's only one way to find out -- empirical testing!
                        Use some dielectric grease on your next set of spark plugs and put it on the metal connectors inside the caps along with the rubber insulator boots, then lightly coat the threads with it instead of your favorite metallic anti-seize compound.
                          Veery interesting !
                          Maybe you haven't had a problem because you sold the bikes.
                          I was told they use it on new cars. My answer to that is, they want me to buy another new car.
                          • donebysunday
                            • Oct 2012
                            • 1737
                            • New Berlin, Wi.
                            If not on the threads, connectors, bullets, battery including batteries in my watch, flashlights, electric plugs (females) in the house, garage, extension cords, USB, mini USB, chargers, solar lights, out door Christmas lights etc..
                            Now I'll need to try it on the threads of the plugs !
                            Marty said, Maybe you haven't had a problem because you sold the bikes.
                            But many of the folks I've sold these bikes to come back to me for years and years, except the ones that have passed on. They have me do maintenance, set carbs, etc.. Not once do I remember electrical.
                            __________________
                            Marty (in Memphis)
                            76 XS650 C ROADSTER
                            80 XS 1100 SG
                              If you’re good with it, go ahead and use it. As for me, I wouldn’t buy a bike that had that stuff on it. We should just agree to disagree.
                              • donebysunday
                                • Oct 2012
                                • 1737
                                • New Berlin, Wi.
                                I'll agree to that !
                                Still leaves me questioning my use of it when everyone disapproves of it's use but me ?
                                If you would not buy a bike with dielectric grease used on it's electrical connections, I certainly will not tell you that I used it on the bike };-)
                                Say is 4-5 PM a good time call to catch you free and easy ?
                                76 XS650 C ROADSTER
                                80 XS 1100 SG
