bleeding the front brake
  • mack
    • 2411
    • Ontario, Canada
    Yes
    It can take a long time to force the air bubbles down. The pesky devils always want to flow back up hill. Don't you remember when we did your 11. Jim pumped and I pumped on that handle for hours before it stiffened up.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
      • 2096
      Originally posted by Blank Slate
      reservoir keeps going down, i keep topping it up without any air getting in, fluid keeps coming out of the calipher, but no tightening of the brake lever.
      when i take a break, i tie up the handle so its pushed in.
      i guess ill just keep at it ��
      The Mity Vac you're using is the only thing needed to bleed successfully, however, it needs to be hooked up properly
      Looks to me the bleeding bottle is omitted in the pic. If the vac in the pic is indeed a Mity vac brand then on page 21 of the tools manual shows the correct setup with the bottle inline between the caliper and the vac pump, BUT there is an orientation of the hoses that needs to be adhered to which you may already know as I'm not lecturing, just sayin'
      With the MV there is no need to squeeze/ pump the brake lever, it sucks all the air out through the bleeder. BUT, the bleeder threads have to be sealed so I slather a coating of grease with a small paint brush around the bleeder screw at the caliper.
      With that said I've bled brakes successfully, for 40 plus years, on many vehicles pumping, holding, releasing, repeating til I got myself a cheap version of the Mity Vac from HF and wallah no more second person (my daughter thanxs me ) pumping, holding, releasing
      That cheap vac's seal went bad so I picked up a real Mity Vac and has worked perfectly on all the vehicles my family owns.
      P.S. page 22 in the MV manual has the MC bleeding info
      BTW, NICE Twin you have there !!!
        • 7818
        The other thing to try is when you have the handle tied down, use something to tap on the upper brake line. Start from the caliper and work your way up. This should allow the small air bubbles to slowly go up to the master cyl.
        • sethhope
          • May 2016
          • 226
          • Springfield, MO
          I second Ray's comment. I spent a good 2 hours tapping bubbles out of my lines when I swapped my stainless lines in. Lots of bubbles trapped in the block on the forks. Not sure why, but air kept getting trapped in there. Keep at it, as it just takes quite a bit of time.
          1979 XS1100F "Roxy" (my first bike ) - '91 Suzuki GSX1100 Fairing, BMW bags, Cheap ABS Trunk, aftermarket cruiser seat, MAC 4-2 exhaust, Heavy Duty folding kickstart, XS11 Special signals and gauges, Blade Fuse Conversion, Dynacoil Greens w/ ballast bypass, SS brake lines
          • Blank Slate
            • Nov 2013
            • 393
            • Ottawa, Ontario, Canada
            Yes Ill keep at it. I tried using the mitivac on the nipple directly, and then the way it’s intended to work, connected to a container and then to the nipple. I didnt know using method 2 that i dont need to pump handle. good to know!!!
            In other news, I did my research and found the size battery I needed (8-1/8 x 3-9/16 x 6-3/8) and went to order a new one. Height ok but a few inches short. Is it going to rattle too much? The connectors are also sideways and my cables are too short, I need new cables or McGuiver something. I hate life right now.
            Frame: 79 XS1100S
            Engine: 81 XS1100S
            Carbs: 78-79 BS34
            Gf bike: 78 XS650S
            Carbs: 70-79 BS38
              • 5073
              Yeah, it "looks" short in terms of length, and too tall. If it is too tall, there could be trouble. I suspect that is why your cables will not reach. Also I question the "UPS" label. If it is an uninterrupted power supply type battery (and not just the name of the company), it may not be suitable for starting an engine (not sure). It is something you want to be sure of in case you need to send it back.
              • Blank Slate
                • Nov 2013
                • 393
                looks like champagne with all the bubbles in my tubes. i mean, bubbles are rushing out hard. Is this a good sign?
                Frame: 79 XS1100S
                Engine: 81 XS1100S
                Carbs: 78-79 BS34
                Gf bike: 78 XS650S
                Carbs: 70-79 BS38
                • Blank Slate
                  • Nov 2013
                  • 393
                  hey sid, it’s not too tall. and i was able to bend the cable in a way to reach. the bike started beautifully. i hope i dont have to remove the battery for years because it was a pain to assemble.
                  Frame: 79 XS1100S
                  Engine: 81 XS1100S
                  Carbs: 78-79 BS34
                  Gf bike: 78 XS650S
                  Carbs: 70-79 BS38
                  • Blank Slate
                    • Nov 2013
                    • 393
                    I read in the yamaha manual not to use a “speed bleeder” nipple. however my oem nipple is badly stripped so it makes opening and closing the nipple difficult. so i had a new speed bleeder lying around and that’s what Im using. just wondering what problem would it cause?
                    Shop Yamaha XS650 parts from XS650 specialists since 2010. Engine rebuild kits, carburetors, ignition and electrical components. Fast shipping. Fitment guaranteed.
                    Frame: 79 XS1100S
                    Engine: 81 XS1100S
                    Carbs: 78-79 BS34
                    Gf bike: 78 XS650S
                    Carbs: 70-79 BS38
                      • 2096
                      www.xs650direct.com/products-50.html
                      The speed bleeder or a stock bleeder, when using the MV, should be treated the same.
                      This is the way I bleed my calipers.
                      1) Top off the MC with brake fluid (leave cover off to monitor level)
                      2) Make sure bleeder nipple can be loosened and it has a good seal on the threads (grease for me)
                      3) Connect MV like you have in your pic
                      4) With nipple closed (either type) pump the MV to at least 15 and stop, make sure you have a good seal and if so, then open nipple, let it draw fluid through then close nipple when the vac gets down around 5 and repeat til no more bubbles come through the line. Remember to check level in MC between each sequence of bleeding.
                      Might take a couple of times but I haven't had to pump the lever at all using the MV and my front brakes, with SS braided lines from XJ4Ever.com, can and are applied with two fingers at every stop.
                      GL
                      P.S. That isn't the correct battery for a motorcycle
                        • 5073
                        The mighty vac has always leaked air around the threads of the bleeder nipple. It will give the impression that there is air in the brake system even when there is none. If you do the mighty vac while pumping the handle, it will give the best results (2-person operation). Of course you might have to move to the other fork side to get out all of the air. I used speed bleeders on both sides and replacing the fluid was quite easy without a mityvac.
                        • Blank Slate
                          • Nov 2013
                          • 393
                          I called the battery customer service because the battery lost its charge overnight. They said their batteries are for ebikes and scooters. suicide smiley
                          Frame: 79 XS1100S
                          Engine: 81 XS1100S
                          Carbs: 78-79 BS34
                          Gf bike: 78 XS650S
                          Carbs: 70-79 BS38
                          • Blank Slate
                            • Nov 2013
                            • 393
                            this battery should be good for my bike, but the amazon database says it’s not good fit fir my bike (1100 79 special). I’ll save 50% over the local store, so Im hoping you guys can confirm it’s a good fit?
                            Frame: 79 XS1100S
                            Engine: 81 XS1100S
                            Carbs: 78-79 BS34
                            Gf bike: 78 XS650S
                            Carbs: 70-79 BS38
                            • Blank Slate
                              • Nov 2013
                              • 393
                              The hits keep coming
                              Topped up my gasoline to the max and when I came back it was leaking over my tank and took a bunch of paint off. I guess I should have dome more coats of the automotive paint? or is there a paint that is gasoline resistant?
                              Not the end of the world because I did the paint myself a few years ago and been meaning to redo it. I just want it to be longer lasting against chips, and gasoline.
                              Frame: 79 XS1100S
                              Engine: 81 XS1100S
                              Carbs: 78-79 BS34
                              Gf bike: 78 XS650S
                              Carbs: 70-79 BS38
                                • 6763
                                IMO any rattle can paint is crap..and will not really hold up to gasoline spills.....
                                2005 Honda SilverWing 600
                                2018 Honda PC-Xpress 150
