I suck at this. I've watched videos, read 3 manuals, I just suck.
Here's what I'm doing:
-I put the bike on side stand so I can get the master cylinder level.
-I take the lid off the reservoir and fill it with brake fluid almost to the top.
-I connect a clear tube to the nipple and the other end of the tube is in a container full of brake fluid, the container is on the floor, below the calipher.
-All the bolts/banjos are tight, and I'm using original brake lines on this 1978 xs650. Reason I'm asking xs11 for advice is because the parts are identical to my 1100.
-So, I pump the handle bar slow, fast, whatever, 20 times. I can see at the bottom of the reservoir hole there are some microscopic bubbles being released, and they're dark probably due to paint.
-I crack open the nipple to let out the air bubbles but nothing comes out that I can see. And that's where my problem is. No pressure is being released at the nipple, and the reservoir level doesn't go down.
-I close the nipple, and try again. 50 pumps, slow fast, crack open the nipple, nothing is happening.
-I even removed the nipple completely and started pumping the brake handle to see if anything was happening, and some brake fluid did squirt out. So there is something happening.
Am I missing something?
