Speaking from experience those needles are very important in the carbs. My bike would start fine and run and rev on the choke when it warmed up it wouldn't transition to the mid range, because of the aftermarket needles. I was lucky and found some NOS ones on ebay. I believe that will be your best bet. I looked everywhere online, called every dealer in Maine, nobody knew where to look. I ended up finding the part number, 452-14116-16-00 and searching for it and found the ones on ebay. Good luck!
