needle jet
  • werdna80
    • Dec 2015
    • 54
    • Grayling, MI
    needle jet
    does anyone know where to find some new needle jets? The PO of the 80G I'm working on now damaged all of them...
    80 G
  • speedlimit85
    • Jan 2017
    • 446
    • Gainesville, Fl.
    https://www.partzilla.com/catalog/ya...00g/carburetor
    80 G
    • werdna80
      • Dec 2015
      • 54
      • Grayling, MI
      So according to the link it's an obsolete part. Does anyone know where I can find a replacement that will work? Or if Mikuni had changed the part numbers? I have the 301 x-2.
      80 G
        • 1580
        Try jetsrus.com
        They used to have genuine Mikuni needles.
        Hope you can find what you need.
          • 2138
          Choices
          Many members on this site swear by genuine Mikuni parts. No doubt you can't go wrong with that choice.
          I have used the needles in the K&L carb kits, and I don't notice a difference:
          https://www.ebay.com/itm/YAMAHA-XS11...RXBuC5&vxp=mtr
          YMMV
          • MPittma100
            • Aug 2011
            • 2359
            Needle Jets
            Are you asking about the air/fuel mixture screws or the needles on the slides, or the main jets that the needles go in and out of?
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
              • 8891
              A needle jet is an emulsion tube. I see them in the carb kits on ebay, may find some 80 ones if lucky. The 78-79 type are different.
              https://www.ebay.com/sch/i.html?_fro...+kits&_sacat=0
              • MPittma100
                • Aug 2011
                • 2359
                Interesting how many names same part can have?
                K&N Air Filter
                ACCT
                EBC Front Rotors
                Mike
                  • 8891
                  Yep, I hear you Mike, it can be confusing at times.
                    needle jet is an emulsion tube...............or metering rod
                      • 8891
                      The 'jet needle' would be the metering rod, no?
                      Not to be confused with the 'needle jet' (emulsion tube) or the 'needle and seat' (fuel valve)
                      • MPittma100
                        • Aug 2011
                        • 2359
                        Exploded View Carb
                        Looking at the attached drawing, it looks like item #55 is the emulsion tube/needle jet. Description calls it nozzle, main. If you do a search for needle jet, it refers to this same item.
                        so, appears this one item has 3 different (maybe more) names?
                        K&N Air Filter
                        ACCT
                        EBC Front Rotors
                        Mike
                          • 2096
                          As per the schematic:
                          #55 - nozzle / emulsion tube
                          #56 - washer for main jet / needle jet ( not just a washer more like a spacer)
                          #57 & #58 - main jet / needle jet ( two numbers are two sizes 115's and 120's )
                          #33 - jet needle
                          werdna80 states he needs a 301x2, not sure if that's the nozzle but I'll be in the garage today and I'll see if I have one.
                            • 734
                            Well, until we here back from Werdna80, I guess we'er really not sure exactly what he needs, but whatever it is, sounds like he needs 4 of them!
                            • werdna80
                              • Dec 2015
                              • 54
                              • Grayling, MI
                              Still need the emulsion tube/needle jet/main nozzle or whatever else it is called... Does anyone know where to find a replacement?
                              80 G
