needle jet
  • werdna80
    • Dec 2015
    • 54
    • Grayling, MI
    needle jet
    does anyone know where to find some new needle jets? The PO of the 80G I'm working on now damaged all of them...
    80 G
  • speedlimit85
    • Jan 2017
    • 491
    • Gainesville, Fl.
    https://www.partzilla.com/catalog/ya...00g/carburetor
    80 G
    • werdna80
      • Dec 2015
      • 54
      • Grayling, MI
      So according to the link it's an obsolete part. Does anyone know where I can find a replacement that will work? Or if Mikuni had changed the part numbers? I have the 301 x-2.
      80 G
        • 1591
        Try jetsrus.com
        They used to have genuine Mikuni needles.
        Hope you can find what you need.
          Choices
          Many members on this site swear by genuine Mikuni parts. No doubt you can't go wrong with that choice.
          I have used the needles in the K&L carb kits, and I don't notice a difference:
          https://www.ebay.com/itm/YAMAHA-XS11...RXBuC5&vxp=mtr
          YMMV
          • MPittma100
            • Aug 2011
            • 2359
            Needle Jets
            Are you asking about the air/fuel mixture screws or the needles on the slides, or the main jets that the needles go in and out of?
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
              A needle jet is an emulsion tube. I see them in the carb kits on ebay, may find some 80 ones if lucky. The 78-79 type are different.
              https://www.ebay.com/sch/i.html?_fro...+kits&_sacat=0
              • MPittma100
                • Aug 2011
                • 2359
                Interesting how many names same part can have?
                K&N Air Filter
                ACCT
                EBC Front Rotors
                Mike
                  Yep, I hear you Mike, it can be confusing at times.
                    needle jet is an emulsion tube...............or metering rod
                      The 'jet needle' would be the metering rod, no?
                      Not to be confused with the 'needle jet' (emulsion tube) or the 'needle and seat' (fuel valve)
                      • MPittma100
                        • Aug 2011
                        • 2359
                        Exploded View Carb
                        Looking at the attached drawing, it looks like item #55 is the emulsion tube/needle jet. Description calls it nozzle, main. If you do a search for needle jet, it refers to this same item.
                        so, appears this one item has 3 different (maybe more) names?
                        K&N Air Filter
                        ACCT
                        EBC Front Rotors
                        Mike
                          • 2104
                          As per the schematic:
                          #55 - nozzle / emulsion tube
                          #56 - washer for main jet / needle jet ( not just a washer more like a spacer)
                          #57 & #58 - main jet / needle jet ( two numbers are two sizes 115's and 120's )
                          #33 - jet needle
                          werdna80 states he needs a 301x2, not sure if that's the nozzle but I'll be in the garage today and I'll see if I have one.
                            • 735
                            Well, until we here back from Werdna80, I guess we'er really not sure exactly what he needs, but whatever it is, sounds like he needs 4 of them!
                            • werdna80
                              • Dec 2015
                              • 54
                              • Grayling, MI
                              Still need the emulsion tube/needle jet/main nozzle or whatever else it is called... Does anyone know where to find a replacement?
                              80 G
