Redonk's build and learning!
  • redonkulos366
    • Aug 2017
    • 35
    • Dallas, Penn.
    #46
    Anyone have any good pictures so I can figure out what is missing ?
    79 F, 81H Venturer parts bike
    92 cb750, 86 vt700, 80 ltd750
    Keep calm and ride on!
      • 7665
      http://store.speedandsportinc.com/ If this link doesn't work, look at the threads below yours, about three down. You should be able to see what the parts look like and the order they go.
      Member andreas may have the part, as he sells used parts and is a GREAT resource for us, and a good guy on top of it!
      • redonkulos366
        • Aug 2017
        • 35
        • Dallas, Penn.
        #48
        that shop is local for me too nice!!
          • 5057
          #49
          Hey Skids,
          That's okay, it just shows you've really got your HEART into helping others!
          :-) Right you are, TC!
            • 5057
            #50
            Originally posted by redonkulos366
            Good news friends and family ... I dumped a **** ton of mmo in that cylinder and let it sit for a few days..... boom 150 psi ... now on to installing this back tire .... this grommet on the rear caliper brace is mangled so I need to replace it but it seems to be obsolete.... 1J7-25374-00-00 SPACER,TORQ.STOP. ..... also how tight do I need to put the rear axlenut on there is no way I can get a torque wrench on it with the long mufflers and if I go too tight the wheel won't spin ??
            It's a new tech tip!
            • redonkulos366
              • Aug 2017
              • 35
              • Dallas, Penn.
              #51
              Does anyone know the size of the luggage rack / sissy bar mounting hardware ? I can't seem to find any diagrams with it?
              • redonkulos366
                • Aug 2017
                • 35
                • Dallas, Penn.
                #52
                well bad news friends... i was on a nice ride around town and the engine just stopped.... it feels like the kill switch is just stuck on ... everything seems to have power with the key on...
                • redonkulos366
                  • Aug 2017
                  • 35
                  • Dallas, Penn.
                  #53
                  is there a way to check the kill switch?
                    Kill switch completes the running circuit. You say everything else 'seems' to work, so I suggest remove the fuel tank and that plug-in associated with switch is on top right side of frame. Check that plug-in with a volt meter with key on. If that doesn't show voltage, remove kill switch, take apart and clean contacts(careful of the teeny internal spring).
                    • redonkulos366
                      • Aug 2017
                      • 35
                      • Dallas, Penn.
                      #55
                      I swapped out another kill switch with no luck 🤔
                        I assume you took apart THAT switch looking for poor contact surfaces or corroded connections before installation? If not, nothing gained.
                        • redonkulos366
                          • Aug 2017
                          • 35
                          • Dallas, Penn.
                          #57
                          Jackpot! Was just a fuse !! It didn't blow the fuse 8n the center, so it was hard to tell !
                            Glad you found the issue.....and it being a simple fix.
                              One thing for sure.......that 'electrikery' can be just that, and majority of time can be a quick fix.
                                • 7665
                                The big question, WHY did the fuse blow???
                                You need to see what happened. Undersized fuse? Wire shorted while riding? Something getting warm and then shorting?
                                Until you know why, it WILL happen again! BTDT I didn't have the ballast resistor fully wrapped, and it shorted about 30 miles from home in the middle of a ride. it DID warn me, but I ignored it..
