Anyone have any good pictures so I can figure out what is missing ?
Redonk's build and learning!
http://store.speedandsportinc.com/ If this link doesn't work, look at the threads below yours, about three down. You should be able to see what the parts look like and the order they go.
Member andreas may have the part, as he sells used parts and is a GREAT resource for us, and a good guy on top of it!Ray Matteis
Originally posted by redonkulos366 View PostGood news friends and family ... I dumped a **** ton of mmo in that cylinder and let it sit for a few days..... boom 150 psi ... now on to installing this back tire .... this grommet on the rear caliper brace is mangled so I need to replace it but it seems to be obsolete.... 1J7-25374-00-00 SPACER,TORQ.STOP. ..... also how tight do I need to put the rear axlenut on there is no way I can get a torque wrench on it with the long mufflers and if I go too tight the wheel won't spin ??Skids (Sid Hansen)
Originally posted by redonkulos366 View Postis there a way to check the kill switch?81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Originally posted by redonkulos366 View PostI swapped out another kill switch with no luck 🤔81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Originally posted by redonkulos366 View PostJackpot! Was just a fuse !! It didn't blow the fuse 8n the center, so it was hard to tell !81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
One thing for sure.......that 'electrikery' can be just that, and majority of time can be a quick fix.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
The big question, WHY did the fuse blow???
You need to see what happened. Undersized fuse? Wire shorted while riding? Something getting warm and then shorting?
Until you know why, it WILL happen again! BTDT I didn't have the ballast resistor fully wrapped, and it shorted about 30 miles from home in the middle of a ride. it DID warn me, but I ignored it..Ray Matteis
