Originally posted by BLOWCLVL
View Post
http://clubs.hemmings.com/xs11/carbspec.htm
Code:
Yamaha XS 1100 Carb Specs Standard UK 78(E) & 80(G) US 78(E) US 79(F) US 80(G) US 81(H) Type BS34-II 2H9-0 BS34-II 2H7-00 BS34-II 2H7-10 BS34-III 3H5-00 BS34-III 3H5-01 Main Jet 132.5 137.5 137.5 115 / 120 115 / 120 Needle Jet X-2 X-2 X-2 X-2 X-2 Jet Needle 5Z1 5GZ6 5GZ6 5IZ7 5IZ7 Clip position 3rd groove 3rd groove 3rd groove Fixed Fixed Pilot Jet 42.5 42.5 42.5 42.5 42.5 Starter Jet 32.5 40 32.5 26 25 Main air jet 140 140 140 140 140 Pilot air jet 180 180 180 185 185 Throttle valve 135 135 135 135 135 Pilot screw (turns out) 1¼ 1¼ 1¼ Preset Preset Float Height 25.7 ± 1 mm 25.7 ± 1 mm 25.7 ± 1 mm 23 mm 23 mm Idle Speed 1050 - 1150 rpm 1050 - 1150 rpm 1050 - 1150 rpm 1100 rpm 1100 rpm Special US 79(SF) US 80(SG) US 80(SH) Type BS34-II 3H3-00 BS34-III 3J6-00 BS34-III 3J6-00 Main Jet 137.5 110 110 / 120 Needle Jet X-2 X-2 X-2 Jet Needle 5GZ6 5GL16 5GL16 Clip position 3rd groove Fixed Fixed Pilot Jet 42.5 42.5 42.5 Starter Jet 32.5 25 25 Main air jet 140 140 140 Pilot air jet 180 185 185 Throttle valve 135 135 135 Pilot screw (turns out) 1¼ Preset Preset Float Height 25.7 ± 1 mm 23.0 mm 23.0 mm Idle Speed 1050 - 1150 rpm 1100 rpm 1100 rpm
