XJ1100 teardown: "We-e-e're off to see the welder, the wonderful welder of ours!"
    Almost There!
    Thanks, Billy! Yeah, it was a totally sweet sound when it just fired up and ran! Handsprings would've been good but not while doing a video.
    Some engine parts are still hot but I found the problem with the shifter.
    The adjuster screw and nut were still locked with the bendy washer but the index was way off.
    It's fixed now and shifts perfectly.
    I pulled the Neutral switch and the tip that rides on the shift drum is chewed up.
    With part of the tip missing it's too short and so close to being ON all the time that it turns on in gear positions that normally wouldn't trip the switch.
    I have a few spare switches so I'll replace it.
    The Oil level sensor is backward from what I thought it would be but it makes sense.
    It couldn't work with the computer self-test/missing sensor routine if it was Open when there was oil.
    Open means the oil level is low or the sensor is not working so there may be a broken wire somewhere that's making the computer light up.
      I replaced the Neutral switch. The light works now so the old switch was bad.
      The flashing light and Oil level warning stopped doing that.
      Huh.
      Oh, well, time to go for a ride!
        XJ1100 Carb Sync and Fuel Levels
        The XJ's fuel levels are good, all within 1mm of the specs.
        #1 is a little higher than the other three so I'll watch the spark plug to see if it has to be lowered.
        Carburetor synchronizing was no problem but it wouldn't have worked without the YICS tool.
        Youtube | XJ1100 Carburetor Synchronizing 0:41
        • donebysunday
          • Oct 2012
          • 1737
          • New Berlin, Wi.
          #94
          Nice gauge set !
          That must have been for professionals only at a professional price ?
          76 XS650 C ROADSTER
          80 XS650 G Special II
          https://ibb.co/album/icbGgF
          80 XS 1100 SG
          81 XS 1100LH/SH DARKHORSE
          https://tinyurl.com/k6nzvtw
          AKA; Don'e, UD, Unca Don'e
            I filled up the gas tank and it got 33 mpg before it was synch'd. That's not bad, I haven't exactly been in fuel-sipping mode.
            Nice gauge set !
            Yeah, it's one of the Internets' finest. It was less money than a Morgan or a Motion Pro set.
            I didn't really want either one of them so I got fleec^H^H^H^H^Hprofessional gauges at a professional price.
            They came in a really keen molded black plastic carrying case with a stylish piece of matching black retaining foam inside to keep them from rattling around.
            It also has a sinister set of threaded chrome tubular type accessories with o-rings for almost any vacuum or synchronizing situation you can imagine and probably some you can't.
            Ah, found a seller:-
            alphamoto | Vacuum Carburetor Synchronizer Carb Sync Gauge
            Note: Stylish matching black foam not shown
              Perfect Ride
              I made a long, hot, ride down to Indio, splitting heavy Memorial Day traffic most of the way for four hours. I made it to the courthouse with five minutes to spare and... they couldn't find the papers I need so I'll go back on Tuesday.
              I rode another hundred miles over the mountains to visit soccermike and Eagle Tom (also crash test dummy). My Baby ran perfectly, didn't use any oil so I'm tired but happy, kickin' back in Mike's kitchen and heading off to sleep.
              More tomorrow when we put Mike's XJ back together!
                • 5048
                #97
                You have to love it when a major project comes off without a hitch!
                  Yes, totally stoked and ready to do some more riding!
                  • XJOK2PLAY
                    • 2099
                    • Skiatook, Ok.
                    #99
                    That's awesome, Scott!
                    Congrats, and hope to ride with ya again soon! Give my best to Mike, too if you're still there.
                    Bob
                    2011 Kaw Concours 14 ABS
                      They're all out running, something to do with another Marathon. I just finished cleaning and checking the bike, time to go see what Tom's doing.
