Starting problems
  • teknoflyver
    • Sep 2015
    • 3
    • Copenhagen, Hovedstaden, Denmark
    Starting problems
    Hi My xs 11 s have an electrial problem sometimes when i turn the key it totaly dead when i leave it with the ignition turn on after a little while it ligths up when i hit the starter button it turns of agin . jens
    81 XS11
    • 2098
    Welcome
    The first thing I would check, in your situation, is the earths(grounds) connections and if the bike still has the original bottle type fuses test each fuse, out of its holder, for continuity.
    A little more info on the bike may help "Us" diagnose the problem quicker
    • teknoflyver
      • Sep 2015
      • 3
      Hi it is a xs 1100 s 1982 5k7 in close to mint condition. i have checked the ground wire from the battery and from the engine and they are ok, could it be some of the contakts on the handlebar!!
      81 XS11
      • teknoflyver
        • Sep 2015
        • 3
        hi forgot to mention battery the is fully charged, all fuses are ok, all wires and conektors have been taken apart and it they semes to be ok
        81 XS11
          • 5073
          Batteries can "charge up" even when they are bad. They can hold a "skin charge" looking like that have 12.5 volts. The problem is that they may not have any capacity at all. You need to charge it and then do a load test to see if it is any good.
            Welcome to the forum!
            Double check specific gravity of the battery (flooded conventional battery) or do a load test (AGM / SVRLA) to make sure it is good.
            If the battery is good and you have already checked everything else that only leaves the Ignition switch.
            I think you need a schematic. Here is a thread where Shappers posted a link to the UK XS1100.com forum with his colour wiring diagram for the 5K7 XS1100
            XS1100.com | Sport (5K7) Colour Wiring Diagram
            Shappers' old-shoebox site is no longer running. I have tried to contact him and the UK xs1100.com site but no luck. I did save a copy of his diagram:-
            Google Drive | SportColourWiringDiagram.pdf 69KB
            • Jeffintampa
              • Apr 2011
              • 344
              • Zephyrhills, Florida
              something to check
              There is a contact above the air that failed on mine. I messed it up taking the carbs in and out on the opposite side of the fuse box
              Bike History:1980 XS 1100 special current bike
              1980 XS 850 special wife sold
                • 2098
                If you're positive the battery is in tip top shape then yes, the problem may be a faulty connection somewhere.
                Time to get the multi-meter out and check for a faulty circuit.
                I have had to repair a failed solder joint in my 80G right handle bar controls as it had an intermittent problem like yours.
                  • 8894
                  Check the ignition switch connector in the headlight bucket, it can overheat and melt causing an intermittent connection.
