new problem...got caught in the rain... (Electrical?!)
    • 9980
    Originally posted by ERM83
    I'm so beyond defeated and pissed off that I'm about to say *&$% it, and get rid of it. I enjoy working on my bikes, but this is just plain ridiculous. I have ZERO IDEA why it won't start now. Makes NO SENSE.
    That's how a lot of us got these bikes.....
    • ERM83
      • Apr 2016
      • 314
      • Lehigh Valley, PA
      #77
      I'm gonna go make sure that I didn't bump the emergency tip switch in a second. It's been TWO WEEKS NOW THAT I HAVEN'T RIDDEN...UNACCEPTABLE! At least, for me...my brother / friends are encouraging me, because "you seem REALLY off lately. GET IT GOING SO WE HAVE NORMAL ERIC BACK."
      Haha, I kid you not...i've heard that multiple times in the past couple of weeks. It's like being in a constant fight with your wife / longtime girlfriend! AAAAAAHHHHH....
      And NO DICE, GREG...I just gotta step away for the night, then come back. I'll always get irate, throw my hands in the air and say stuff I don't mean.
      80' XS1100 SG "Dottie"
      79' SF carbs
      MAC 4-1
      K&N Pods
      Accel 3.0 coils
      Tarozzi fork brace
      TC fusebox
      Picture update soon
      http://i53.photobucket.com/albums/g4...psej6wqu9l.jpg
      79' XS1100 SF (parts, will be reborn)
      http://i53.photobucket.com/albums/g4...snfgpozqn.jpeg
      • ERM83
        • Apr 2016
        • 314
        • Lehigh Valley, PA
        #78
        Once again, spent ALL DAMN DAY working on it...new plugs, cleaned THE HELL out of the carbs...WILL. NOT. SYART. I DON'T KNOW WHAT I'M MISSING, OR WHAT TO DO.
        79' SF carbs
        MAC 4-1
        K&N Pods
        Accel 3.0 coils
        Tarozzi fork brace
        TC fusebox
        Picture update soon
          • 9980
          Air, fuel, compression, spark.
          • ERM83
            • Apr 2016
            • 314
            • Lehigh Valley, PA
            #80
            UPDATE: i've gotta haul ass to work, so i gotta make it quick....
            I remembered that the ignition goes through the right handle bar cluster...moved it around when i changed the throttle cable last night, moved it around a few minutes ago, and it fired right up.
            second: despite cleaning out the carbs (also the T - fuel connections), still not getting fuel to no. 2. sprayed some starting fluid in there, and it SCREAMED. put me in a better mood. I dunno what i'm missing with the carbs, though...so weird. everything looked completely fine...will report back...
            79' SF carbs
            MAC 4-1
            K&N Pods
            Accel 3.0 coils
            Tarozzi fork brace
            TC fusebox
            Picture update soon
            • vedgar
              • 311
              • Clarkston, Michigan
              #81
              congratulations !
              You have nothing to fear. It is just metal and plastic and you don't have to fix it to make a living. I was a Jaguar Technician for a living. ( A living hell sometimes). My advice to spray the #2 carb has got you on the right path. I cant be with you in person but will guide you to Nirvana. ( running bike) You are not getting the correct fuel to #2 carb. Find out why . #1 is there fuel in the bowl (no) fix it. Yes ( It is not getting to the choke circuit or the idle circuit)
              Do not pass go do not collect 200 dollars til You have the answers to the fuel in #2 question..
              79 1100 SF Carmine Red stock
              85 Honda v65 Magna
              • ERM83
                • Apr 2016
                • 314
                • Lehigh Valley, PA
                #82
                I cleared out the t- fitting ports to carb 2...I'm going to loosen the bolt on the bottom of the bowl to MAKE SURE that fuel is coming in there. Could it be the octopus???
                79' SF carbs
                MAC 4-1
                K&N Pods
                Accel 3.0 coils
                Tarozzi fork brace
                TC fusebox
                Picture update soon
                  The octy wouldn't starve one carburetor, it'd starve the pair it's feeding: 1&2 or 3&4.
                  Did you unscrew the needle seats when you cleaned the carbs? It'd be pretty extreme but a plugged inlet screen on the needle valve seat would starve one carburetor.
                  Also, have you checked the brass floats for leaks? Stick them in a pot of hot water and watch for streams of bubbles. Leaky floats fill with fuel and get heavy, then they don't shut off the fuel at the right level and the carb runs rich or overflows.
                    • 9980
                    The octy actually acts as an H connection and feeds all 4 from both petcocks Scott.
                      Hmm, I'll have to re-check that, I've never actually taken one apart. It's got two inlets and two outlets....
                      A few screws and swipes with a razor blade later: Yep, internally it's an "H" with one o-ring to rule them all.
                      It's no wonder it leaks.
                        • 7793
                        ERM83,
                        As 3Phase said, it's probably the fuel inlet screen on the needle seat. it's a 10mm to take it out, so you CAN do it on the bike with some cussing. To clean, spray carb cleaner from the bowel side of the seat to blast the crud out. Just be careful not to lose the screen! It's not needed to run, but is your last defense against crud getting into the carbs.
                        The handlebar switch MAY have some wires that have broken at the solder joints. It's pretty easy to take the two halves apart and just use a solder iron to re-melt the solder on each wire. That will keep it running for another 30 years.
                        I know it's been hard, but you are almost there!
                        • ERM83
                          • Apr 2016
                          • 314
                          • Lehigh Valley, PA
                          #87
                          Ok....so yesterday, I THOUGHT it was the screen. It looked like CRAP, so I cleaned the hell out of it. Put'em back on, fired it up, and still the same thing. I'm going to check the float...
                          79' SF carbs
                          MAC 4-1
                          K&N Pods
                          Accel 3.0 coils
                          Tarozzi fork brace
                          TC fusebox
                          Picture update soon
                          • ERM83
                            • Apr 2016
                            • 314
                            • Lehigh Valley, PA
                            #88
                            Also, on PRIME, still quieter on the left side. That was my initial screw-up...NOT loud ENOUGH on the left side! SO CLOSE, GUYS...
                            79' SF carbs
                            MAC 4-1
                            K&N Pods
                            Accel 3.0 coils
                            Tarozzi fork brace
                            TC fusebox
                            Picture update soon
                            • ERM83
                              • Apr 2016
                              • 314
                              • Lehigh Valley, PA
                              #89
                              ERM83,
                              You know, I got PSYCHED when I took the seat out yesterday. NOTHING was getting through there. Cleaned it; excitedly put the carbs back on. STILL THE SAME THING. I'm about to test the float, but I'm starting to think the worst...(valves). I'm not sure what else it could be.
                              79' SF carbs
                              MAC 4-1
                              K&N Pods
                              Accel 3.0 coils
                              Tarozzi fork brace
                              TC fusebox
                              Picture update soon
                                • 9980
                                Because the tank has 2 outlets and the carbs have 2 inlets.
                                That's why mine was deleted long ago and an H connection put in the lines. After the second or third failure on LD rides it became apparent that just shutting off the petcocks (if necessary) was much less trouble than bypassing that PITA on the road.
