Point of No Return!
Hey there folks,
Okay, got a fair amount of stuff done today. Took off handlebars, rear and front calipers and brakes/master cylinders, cruise pads/forward controls, Aux Lights, footpegs, aluminum peg brackets, headlight, gauge cluster, front wheel, triple tree/forks, and the entire eletrical harness! Had taken off the engine rotor from the right side, and found a fair amount of grunge/evidence of oil that has probably leaked out around the crank seal. I know what you're thinking, that the oil was actually leaking from the galley plug at the bottom of the alt chamber, but I had replaced that seal / O-ring just a year or so ago when I did the Mini Race Alt Mod.
Then took off the left timing cover, and timing parts, and found this.
Then I looked closer and realized that the left crank seal doesn't appear to have been leaking, but the GALLEY PLUG has been. It's just sealed with an O-ring and after 30 years, it's gotten compressed, and apparently has been leaking....thus all of the grunge on the timing cover and side of the engine. However, some of that may also have been leaking from the valve cover down the front of the engine and windblown around, and some of it was from my old OEM style CCT that I know had leaked in the past!
Here's what's left of the tear down.
And these two show how I've made it into a convertible frame!
Have cut the frame off just above the motor mounts front and back, and will be welding some angle iron to them so that I'll be able to then secure them to my engine stand. I have made a HOIST out of some 2" x 8" x 8feet sections of old bed frame rails that I have repurposed, have braced it so it won't tilt over, mounted a nice strong O hanger bracket that I'll be attaching a come-along, and I'll be able to position it over the bike lift to be able to hoist it up and then mount it to the engine stand, so I can then do both cleaning and work on the engine....the crank seals, the timing chain, shift cover, clutch cover and new springs, along with painting, polishing and such!
Hey there folks,
