gaskets
  • CatatonicBug
    • 6117
    • Clinton, UT
    I'll chime in here. I highly recommend the stuff in a pressurized can called "The Right Stuff". It comes with an applicator tube, and you just press the tube to one side to dispense. Comes out in a nice, clean bead, with no mess. When I have had to remove the stuff, a wire brush cleans it off easily. I used a wire wheel on a drill to "grind" the OEM gasket material off years ago.
      Though I disagree with C-bug on using a wire wheel on the aluminum gasket surface, I do agree with him on "The Right Stuff". A bit pricey, but has worked better than anything else I've tried.
      • Rasputin
        • 3189
        • Lacombe, Alberta, Canada
        +1 on The Right Stuff! (Best ever for every gasket on these bikes with the exception of the head gasket). Easily applied, removed, and superior sealing. I use nothing else.
        2-79 XS1100 SF
        2-78 XS1100 E Best bike Ever
        • MindWebs
          • May 2009
          • 431
          • Baldwin, WI
          silicone..
          silicone product are the handiest items but...
          they must be applied with care!!!!
          small beads/light coat!
          if you apply too much it can squeeze to the inside of the engine.
          if it comes loose inside your motor it can clog oil ports and make a real nuisance of itself, ans could potentially do harm to the motor.
          but again, apply lightly and it's a great product.
          i prefer Pam cooking spray, buy 1 set of new gaskets and spray the "dry" gaskets down with pam so they release the next time the cover is removed.
          that also works great.
