I'll chime in here. I highly recommend the stuff in a pressurized can called "The Right Stuff". It comes with an applicator tube, and you just press the tube to one side to dispense. Comes out in a nice, clean bead, with no mess. When I have had to remove the stuff, a wire brush cleans it off easily. I used a wire wheel on a drill to "grind" the OEM gasket material off years ago.
gaskets
-H. Ford -
Though I disagree with C-bug on using a wire wheel on the aluminum gasket surface, I do agree with him on "The Right Stuff". A bit pricey, but has worked better than anything else I've tried.Try your hardest to be the kind of person your dog thinks you are.
+1 on The Right Stuff! (Best ever for every gasket on these bikes with the exception of the head gasket). Easily applied, removed, and superior sealing. I use nothing else.2-79 XS1100 SF
Couple of more parts bikes of which 2 more will live!Comment
silicone..
silicone product are the handiest items but...
they must be applied with care!!!!
small beads/light coat!
if you apply too much it can squeeze to the inside of the engine.
if it comes loose inside your motor it can clog oil ports and make a real nuisance of itself, ans could potentially do harm to the motor.
but again, apply lightly and it's a great product.
i prefer Pam cooking spray, buy 1 set of new gaskets and spray the "dry" gaskets down with pam so they release the next time the cover is removed.
that also works great.1979 XS1100SF Special.78 E motor/carbs, Jardine 4-2 exhaust, XS Green coils, Corbin seat, S.S. Brake lines, Hard cases, Heated grips.
Most bike problems are caused by a loose nut connecting the handlebars and the seat!!Comment
