Bikes in the Bax Cave
    • 7819
    Work? That is a four letter word!
    Oh yeah, I'm retired! Have a safe ride!!!!
    • Bax
      • 344
      • Merrimack, NH
Name:	NH_2020_End of Riding Season.JPG
      This S*&^ is usually the sign that I took my last ride of the year here in NH and the bikes go into hibernation for a long Winter nap............ Sights on 2021.
      ---Bax
        • 7819
        Yeah, I'm about a month out from there, I HOPE!
          • 1987
          Hey Bax,
          I read through this thread. One thing that had not been mentioned but needs to be checked is the rotor alignment. When I say alignment.. maybe not the right word... more like centered. When you look down on the rotors in relationship to the calipers they should both be centered between the brake pads .. left and right. To adjust this you have to loosen the castle nut on the shaft and the bolt on the left fork. Takes some back and forth and you will be able to see the movement as you play with them. Might help a tad with the brake drag and possibly the wobble pulse you are feeling. As Ray said it is still a good idea to check the steering bearings. I just put the bike on the center stand then lean the bike up and place a jack stand under the front brace to get the front wheel and forks off the ground. That way you can push and pull the front as well as rotate it left and right while feeling if you have in slop in the bearings.
          • Bax
            • 344
            • Merrimack, NH
ID:	860370Click image for larger version
            • Bax
              • 344
              • Merrimack, NH
              Hi Cajun, Yeah, the centering took a bit of extra effort and parts to resolve. Not sure of the cause but this bike was off about 0.9mm from a centered rotor on the left fork (non adjustable side). I had to add shims to the stack up on the axle to return the forks to a parallel condition and rotor center. Along with several other small tweaks the brakes now work well with no pulsing or drag.
              Bax
                • 1987
                Looks great. Of course you know the next question has to be the source of the shim rings and size. Anything that makes this job easier I am in for.
                • Bax
                  • 344
                  • Merrimack, NH
                  Hi Cajun, Seems this forum is truncating a few pics from my post if "Latest Activity" is checked. There are 5 pics total on #20, if you go to page 2 and scroll down its all visible. I purchased those shims directly from Misumi. For the specials at least the ID is 17mm OD 28mm and I went with a 0.3mm thickness that I could stack for my adjustment. They come in a 30 pack so a lower thickness is definitely adequate but I suspect would be "fun" during the assembly sliding the axle through. I went with stainless option for the material.
                  https://us.misumi-ec.com/vona2/detai...wysiwyg_area_0
                  ---Bax
