New member, build issues
    • 9981
    Originally posted by beastcoastxs
    I'm talking about the cap on the side of the gearbox not the drain plug. Like I said though, I found a gasket online no worries.
    The fill plug for the middle drive right?
    That's what I'm talking about.
    Or do you mean the engine oil fill plug?
      • 8893
      He means the chrome cap on the side with the 4 bolt holes with the big nut and bearing underneath.
      • beastcoastxs
        • Dec 2015
        • 18
        • Jacksonville, FL (Lakeshore)
        #48
        thanks
        Thought I was going crazy there for a second. Thank you. haha
        79 xs1100 Special/FrankKenBike
        08 XL1200 EFI Rubbermount
        4 Wheeled driving machine:
        94 F150 XLT
          • 9981
          Nope, I'm the crazy one. Misunderstood what you meant, didn't pay enough attention.
          Try this......... http://www.ebay.com/itm/79-YAMAHA-XS...qA1B6g&vxp=mtr
          Or this........... http://www.ebay.com/itm/80-XS1100-XS...jX_ZtQ&vxp=mtr
            Don't feel bad.........as I was thoroughly confused.
            • beastcoastxs
              • Dec 2015
              • 18
              #51
              brake rotor lockwashers
              I was just looking for the gasket but I found one already. Thanks though guys.
              On to the next question...
              I ordered the brake caliper brackets from pandemonium and sorted out a ton of brake parts I have sitting around. When I took off the rotors most of the "lock washers" on the rotor bolts feel apart. I know I can order them online but that will require more waiting. Anything wrong with loctite or a single lockwasher per bolt?
              94 F150 XLT
                #52
                Hey there,
                Blue Locktite and lockwasher is fine. Wish I had known that when I rebuilt mine, those OEM washers were $$ !
                  • 9981
                  I've been running just 5/16 lock washers for years. Locktite might be ok but I would be wary of pulling threads on the aluminum wheel.
                  I never had one even try to loosen up with just lock washers.
                    Hi Beast,
                    I would be worried about the Loctiet in aluminum too.
                    Did both tabs break ? You could also drill the bolt heads and safety wire them. Make it look really racy then eh!
                      • 8893
                      I've been using single lockwashers with locktite blue for years with no problems. I would be more worried about them coming loose than a problem with the threads. When I need to remove a rotor, the bolts come out no problem and no kind of thread damage, YMMV.
                      • beastcoastxs
                        • Dec 2015
                        • 18
                        #56
                        sounds awesome but...
                        That is a great idea if I had all the toolage for a proper safety wire job. But, I have loctite and lockwashers at home already so I'll stick with that.
                        Hi Beast,
                        94 F150 XLT
                          • 8061
                          If you should decide you want them, Mike's XS has 'em.
                          Bolt Lock Tabs for Disc Brake Rotor
                          • beastcoastxs
                            • Dec 2015
                            • 18
                            #58
                            Thanks man but I already installed with loctite. She's back on the road... WITH a front brake. I got that setup from pandemonium and I'm running the brembo seup but decided to go with single disc instead of dual. I need to get the exhaust swapped out with the 4-1 setup I have sitting in the garage. I have a bit of a popping issue with cyl 4 but other than that she's running great. I haven't had much time to take a look at it but the popping is either an intake or exhaust leak or exhaust issue I'm hoping instead of a hanging valve or something.
                            I'll have pics of the progress soon but my phone is on the fritz lately.
                            94 F150 XLT
