New member, build issues
    • 9981
    Originally posted by beastcoastxs
    I'm talking about the cap on the side of the gearbox not the drain plug. Like I said though, I found a gasket online no worries.
    The fill plug for the middle drive right?
    That's what I'm talking about.
    Or do you mean the engine oil fill plug?
      He means the chrome cap on the side with the 4 bolt holes with the big nut and bearing underneath.
      • beastcoastxs
        • Dec 2015
        • 18
        • Jacksonville, FL (Lakeshore)
        #48
        thanks
        Thought I was going crazy there for a second. Thank you. haha
        79 xs1100 Special/FrankKenBike
        08 XL1200 EFI Rubbermount
        4 Wheeled driving machine:
        94 F150 XLT
          • 9981
          Nope, I'm the crazy one. Misunderstood what you meant, didn't pay enough attention.
          Try this......... http://www.ebay.com/itm/79-YAMAHA-XS...qA1B6g&vxp=mtr
          Or this........... http://www.ebay.com/itm/80-XS1100-XS...jX_ZtQ&vxp=mtr
            Don't feel bad.........as I was thoroughly confused.
            • beastcoastxs
              • Dec 2015
              • 18
              #51
              brake rotor lockwashers
              I was just looking for the gasket but I found one already. Thanks though guys.
              On to the next question...
              I ordered the brake caliper brackets from pandemonium and sorted out a ton of brake parts I have sitting around. When I took off the rotors most of the "lock washers" on the rotor bolts feel apart. I know I can order them online but that will require more waiting. Anything wrong with loctite or a single lockwasher per bolt?
              94 F150 XLT
                #52
                Hey there,
                Blue Locktite and lockwasher is fine. Wish I had known that when I rebuilt mine, those OEM washers were $$ !
                  • 9981
                  I've been running just 5/16 lock washers for years. Locktite might be ok but I would be wary of pulling threads on the aluminum wheel.
                  I never had one even try to loosen up with just lock washers.
                    Hi Beast,
                    I would be worried about the Loctiet in aluminum too.
                    Did both tabs break ? You could also drill the bolt heads and safety wire them. Make it look really racy then eh!
                      I've been using single lockwashers with locktite blue for years with no problems. I would be more worried about them coming loose than a problem with the threads. When I need to remove a rotor, the bolts come out no problem and no kind of thread damage, YMMV.
                      • beastcoastxs
                        • Dec 2015
                        • 18
                        #56
                        sounds awesome but...
                        That is a great idea if I had all the toolage for a proper safety wire job. But, I have loctite and lockwashers at home already so I'll stick with that.
                        Hi Beast,
                        94 F150 XLT
                          If you should decide you want them, Mike's XS has 'em.
                          Bolt Lock Tabs for Disc Brake Rotor
                          • beastcoastxs
                            • Dec 2015
                            • 18
                            #58
                            Thanks man but I already installed with loctite. She's back on the road... WITH a front brake. I got that setup from pandemonium and I'm running the brembo seup but decided to go with single disc instead of dual. I need to get the exhaust swapped out with the 4-1 setup I have sitting in the garage. I have a bit of a popping issue with cyl 4 but other than that she's running great. I haven't had much time to take a look at it but the popping is either an intake or exhaust leak or exhaust issue I'm hoping instead of a hanging valve or something.
                            I'll have pics of the progress soon but my phone is on the fritz lately.
                            94 F150 XLT
