Thanks man but I already installed with loctite. She's back on the road... WITH a front brake. I got that setup from pandemonium and I'm running the brembo seup but decided to go with single disc instead of dual. I need to get the exhaust swapped out with the 4-1 setup I have sitting in the garage. I have a bit of a popping issue with cyl 4 but other than that she's running great. I haven't had much time to take a look at it but the popping is either an intake or exhaust leak or exhaust issue I'm hoping instead of a hanging valve or something.
I'll have pics of the progress soon but my phone is on the fritz lately.
New member, build issues
If you should decide you want them, Mike's XS has 'em.I ordered the brake caliper brackets from pandemonium and sorted out a ton of brake parts I have sitting around. When I took off the rotors most of the "lock washers" on the rotor bolts feel apart. I know I can order them online but that will require more waiting. Anything wrong with loctite or a single lockwasher per bolt?
Bolt Lock Tabs for Disc Brake RotorLeave a comment:
sounds awesome but...
That is a great idea if I had all the toolage for a proper safety wire job. But, I have loctite and lockwashers at home already so I'll stick with that.
Leave a comment:
I've been using single lockwashers with locktite blue for years with no problems. I would be more worried about them coming loose than a problem with the threads. When I need to remove a rotor, the bolts come out no problem and no kind of thread damage, YMMV.Leave a comment:
Hi Beast,
I would be worried about the Loctiet in aluminum too.
Did both tabs break ? You could also drill the bolt heads and safety wire them. Make it look really racy then eh!
PhilLeave a comment:
I've been running just 5/16 lock washers for years. Locktite might be ok but I would be wary of pulling threads on the aluminum wheel.
I never had one even try to loosen up with just lock washers.Leave a comment:
Hey there,
Blue Locktite and lockwasher is fine. Wish I had known that when I rebuilt mine, those OEM washers were $$ !
T.C.Leave a comment:
brake rotor lockwashers
I was just looking for the gasket but I found one already. Thanks though guys.
On to the next question...
I ordered the brake caliper brackets from pandemonium and sorted out a ton of brake parts I have sitting around. When I took off the rotors most of the "lock washers" on the rotor bolts feel apart. I know I can order them online but that will require more waiting. Anything wrong with loctite or a single lockwasher per bolt?Leave a comment:
Nope, I'm the crazy one. Misunderstood what you meant, didn't pay enough attention.
Try this......... http://www.ebay.com/itm/79-YAMAHA-XS...qA1B6g&vxp=mtr
Or this........... http://www.ebay.com/itm/80-XS1100-XS...jX_ZtQ&vxp=mtr
Don't feel bad.........as I was thoroughly confused
Leave a comment:
Or this........... http://www.ebay.com/itm/80-XS1100-XS...jX_ZtQ&vxp=mtrLeave a comment:
He means the chrome cap on the side with the 4 bolt holes with the big nut and bearing underneath.Leave a comment:
I'm talking about the cap on the side of the gearbox not the drain plug. Like I said though, I found a gasket online no worries.
Leave a comment:
The middle drive cap can be replaced with an oil pan plug from any parts house. As a matter of fact it makes it easier to R&R when yo need to check or change the fluid.
Just take the old one with to match up size and thread. A little longer won't hurt.Leave a comment:
Leave a comment:
