Vacum draw
  • mack
    • 2411
    • Ontario, Canada
    Lol
    Brant I learn from it but feel bad when I cause it.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
      Oh Brant, I said 16+ (remember that plus sign there, that means at least that but probably more) because I don't remember what the exact number is. If I remember the exact number I would not have used the + sign.
        Mack, your information input always has ADDED to the knowlwdge here, least for me.
        Your questions have seemed to always bring out good points from others that also ADD to knowldge here.
        Feel bad?......not even close my fellow XSer.
        Nate, the 16in.vac. number brought to my attention a mal-function goin' on
        The +sign just left a still questionable, possible issue.
          Of all the XS11's I've synced here at sea level, I always get approx. 10" on my gauges.
            Rich idle mixture settings WILL do that, IF your setting them by highest in. vac.. Lean-drop method is the ONLY correct way of setting idle mixtures, whether it be 'old school' carburated automotive engines OR motorcycles. BTW, NOT my opinion, just a fact that's how it's PROPERLY done. If your positivly nothing else is array, try it.....bet you'll see 22in. across all four, and a smoother running engine than you previously THOUGHT it was.
            • mack
              • 2411
              • Ontario, Canada
              Ok
              So Please artculate the "lean drop method". Just for those of us who cannot identify with the "motorhead" monicer!
              mack
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              613-398-6186
                Yes, I remember years back using the mercury sticks and getting the high perhaps 22 readings but the type of gauges I use now read always about 10. I use the highest reading when setting the mixtures, no way on earth it would ever raise anywhere even near 22.
                  Refer to post#15, third comma seperated portion.
