Vacuum adv hangs up
  • Prisoner6
    • Aug 2013
    • 1184
    • Phoenix, AZ
    No. You may run the vacuum shutoff (octy, octopus, spidervalve, POS) from any manifold you choose.
    I think that says it all ...
    Marco
    1979 Honda CBX
    2002 Kawasaki ZRX1200R
    WE MISS YOU, DON
      • 7815
      For the record, I maintain mine.
      • Prisoner6
        • Aug 2013
        • 1184
        • Phoenix, AZ
        I've been vacillating for a long time about ditching the Octy ... in the foreseeable future (unless I can come up with a really good reason to ditch it), I'll be keeping mine as well ...
        Marco
        1979 Honda CBX
        WE MISS YOU, DON
          • 7815
          It's a safety device. Once you get it properly plumbed, it's no big deal having it on there. I've had two failures, and both times, it failed open.
            • 7703
            +1 on what Marty said, except for the failures. I've only had 1 failure, and it was just a dribble.
            • Prisoner6
              • Aug 2013
              • 1184
              • Phoenix, AZ
              Mine is working properly. Sometimes I think it would be nice to have the extra room in there (without all that extra plumbing) ...
              But then the idea of having that extra safety measure comes back to my mind, so I keep the Octy.
              Marco
              1979 Honda CBX
              WE MISS YOU, DON
              • alaskey2
                • Apr 2014
                • 271
                • 60940
                Oh ok, thanks. I'm all good
                78 E
                • hondakid11
                  • Apr 2015
                  • 39
                  • Lockport, N.Y.
                  Originally posted by trdriver71
                  If I were you I would check your valve clearances I had the same thing on my bike turned out that almost all of my valve were tight.
                  Just got done checking valve clearance and low and behold they're all tight... heading to the bike shop tomorrow to get the rights size shims and I'll go from there. Thanks tr driver
                  79 XS1100SF k&n pod filters
                  emgo shorty mufflers (w/o baffles)
                  chopped rear
                  springer seat
                  led turn signels
                  led brake light
                  side mount verticle plate
                  drag bars.
                  86 Suzuki Intruder VS700
                  8" biltwell chumps
                  chopped rear
                  nasty twins drag pipes
                  • Rasputin
                    • 3189
                    • Lacombe, Alberta, Canada
                    If you have a hanging idle you are running too lean. If after the change in valve shims, you experience the same problem, then you are running too lean mixture. Can burn up an engine, so be sure about your settings. check your plug color too.
                    2-79 XS1100 SF
                    2-78 XS1100 E Best bike Ever
                    • hondakid11
                      • Apr 2015
                      • 39
                      • Lockport, N.Y.
                      Actually I'm on the rich side. I'll get my shims right and re sync and go from there.
                      chopped rear
                      springer seat
                      led turn signels
                      led brake light
                      drag bars.
                      8" biltwell chumps
                      chopped rear
                      • Rasputin
                        • 3189
                        Where are you too rich? At idle, wide open throttle? How are you checking? Many ranges to these carbs and all interact with each other.
                        2-79 XS1100 SF
                        • hondakid11
                          • Apr 2015
                          • 39
                          • Lockport, N.Y.
                          I'm good on fuel mixture throughout all 4 ranges. I have colortune and check my plugs regularly. I'm good with carbs and fuel mixture ratios. I know I'm not lean cause I set it up to be more on the richer side trying to compensate for the hang idle. I should also mention that it is fine when cold and only does this when it's warm which is why I'm leaning to my valves. I had just never checked them. I'll post a reply tomorrow after I get everything back together tomorrow and let you guys know if valves was my issue or if we need to start rechecking things.
                          Thanks for all the imput.
                          chopped rear
                          springer seat
                          led turn signels
                          led brake light
                          drag bars.
                          8" biltwell chumps
                          chopped rear
                          • hondakid11
                            • Apr 2015
                            • 39
                            • Lockport, N.Y.
                            solution
                            i've noticed with many forums, not just this one, that people do not put the solution to the issue after they solved it. sooooooo....
                            it turned out that my valves were all .05mm too tight. so i went to the local stealer dealer adn picked up some shims.
                            got everything back together and shes runnin like a raped ape and doesnt have a hanging idle issue anymore.
                            only problem now is that my 2nd gear is having a some trouble with the new found power... more on that later.
                            but i am very appriciative to the info that everyone provided as i am new to this forum, and new to the bike. my first yamaha and my first inline 4. couldnt be more happy with it!
                            HAPPY TRAILS!!
                            chopped rear
                            springer seat
                            led turn signels
                            led brake light
                            drag bars.
                            8" biltwell chumps
                            chopped rear
                              • 7703
                              Go VERY LIGHT on second gear and it MAY take you through this season. It's a known problem that Yamaha didn't fix until 1986, and the second generation on the VMax and Venture. They used the transmission out of the XS11, so think about that.....
                              The fix CAN be done in a weekend, but you MUST take it easy on what is there now to make it easy. The shift fork WILL go quickly.
                              Enjoy the bike, just wait until 3rd to jump on it.
                              Oh, and for racing, I tell everyone put it in your highest gear, slow to 25MPH, and then we go. NO ONE is willing to try it?!?! Alway's go to your bikes strong side...
                              • hondakid11
                                • Apr 2015
                                • 39
                                • Lockport, N.Y.
                                yea i took it to the track last night and thats when the 2nd gear happened. oh well.. it was fine on the way home. i have to take it easy, cause i have a trip coming up and have to get my gf's bike ready. oh yay.
                                chopped rear
                                springer seat
                                led turn signels
                                led brake light
                                drag bars.
                                8" biltwell chumps
                                chopped rear
