Vacuum adv hangs up
    Thanks for the follow-up, hondakid11!
    I know I keep telling people to check the engine compression, valve clearances and mechanical timing before spending money and time diving into the carburetors and electrical system but usually no one does it until after the carburetors have been strewn all over the place along with the wiring harness and a few other -- now broken -- bits and pieces and the engine still won't run right.
    Take it easy on 2nd gear and have fun: Good job!
      Originally posted by hondakid11
      i've noticed with many forums, not just this one, that people do not put the solution to the issue after they solved it.
      Thank you for posting the conclusion- increases the knowledge base, and rewarding for those who helped.
      • trdriver71
        • 360
        • Edmonton Alberta
        Glad to hear it is running good for you now except the second gear issue I had to get that fixed too. That one is thanks to Rasputin.
        '79 XS11SF
