Vacuum adv hangs up
  • hondakid11
    • Apr 2015
    • 39
    • Lockport, N.Y.
    Vacuum adv hangs up
    my adv is hanging up and not coming down unless i release the clutch at a standstill and force the idle to drop. it will idle fine, but once you rev to about 2500 rpm, it "sticks" (ive watched it with the timing cover off)
    things ive done:
    cleaned carbs thoroughly
    snyced
    colortuned
    timed
    double checked sync
    double checked timing (mach adv works fine)
    checked for vacuum leak with carb cleaner spray.
    ripped out my hair
    tried to run without vac adv (runs rough)
    tried to use motion pro syncpro resticter (made the adv not move)
    if i rev it up it will hang at like 3000 rpm until i either put it in gear and release the clutch, or take my finger and push the vacuum advance down...
    any ideas?
    79 XS1100SF k&n pod filters
    emgo shorty mufflers (w/o baffles)
    chopped rear
    springer seat
    led turn signels
    led brake light
    side mount verticle plate
    drag bars.
    86 Suzuki Intruder VS700
    8" biltwell chumps
    chopped rear
    nasty twins drag pipes
    • 7763
    I believe the vacuum advance is supposed to come in at engine start. The mechanical advance comes in at 5000 rpm. Are you saying your idle won't come down? Your carburetors probably need to be bench synced properly. Your description leads me to believe they're way out of sync. There must be an error somewhere.
    Ignition timing set with vacuum advance hose capped, correct? Mechanical advance comes in at 5000 rpm, correct?
    • hondakid11
      • Apr 2015
      • 39
      • Lockport, N.Y.
      yea the carbs were vacuumed synced multiple times during all the processes. mechanical adv was set and checked with vac hose off and plugged. comes in at 5000 rpm at 31 degrees. but the idle doesnt hang with the vacuum hose disconected. so i know this is a vacuum adv issue.
      ive been all up and down this forum for the last 3 months. but just now was able to join.
      chopped rear
      springer seat
      led turn signels
      led brake light
      drag bars.
      8" biltwell chumps
      chopped rear
        • 7763
        The vacuum advance is connected to the port in the #2 carburetor, correct? Did you check the vacuum diaphragm for a leak? The hose as well?
        What you describe sounds like a bad sync. Before you hooked up a manometer or gauges, did you bench sync the carburetors? That's actually very important.
        Set the butterflies to this position, where you have half a hole showing.
        This thread may be helpful to you, until someone responds who knows more than I do.
        • SFerinTEXAS
          • Jun 2006
          • 876
          Where are you connecting the vac hose? int boot or #2 carb?
          79SF
          XJ11
          78E
          • donebysunday
            • Oct 2012
            • 1737
            • New Berlin, Wi.
            If I may, the hose goes to the carb not the boot.
            76 XS650 C ROADSTER
            80 XS650 G Special II
            https://ibb.co/album/icbGgF
            80 XS 1100 SG
            81 XS 1100LH/SH DARKHORSE
            https://tinyurl.com/k6nzvtw
            AKA; Don'e, UD, Unca Don'e
            • hondakid11
              • Apr 2015
              • 39
              • Lockport, N.Y.
              Connected to #2 carb body brass nipple. Sync was done properly. Carbs do not have vac leaks nor tears in cv diaphram. I didnt pull the vac canister off the pick up assy. If it were leaking there it wouldnt pull the adv.
              Im thinking this may be worn springs inside the vac adv mechanism.
              **sorry for all caps, im at work and have to use caps, not going to re type lol**
              chopped rear
              springer seat
              led turn signels
              led brake light
              drag bars.
              8" biltwell chumps
              chopped rear
              • TADracer
                • May 2006
                • 1417
                • Kenner, Louisiana USA
                If it is sticking or if it has a leak they both should be easy to determine. With engine off, rotate the pickup coils by hand. They should turn easily and snap back to the base position under spring pressure on the centrifugal advance mech. If not then remove, clean and lube the centrifugal advance. Then disconnect the hose from the #2 carb (the carb, not the #2 boot is where it is connected) and pull about 5-6 in. vacuum on it and the vacuum mech should pull in and move the timing plate with the pickup coils. You can do it with your mouth if you don't have a hand vacuum pump. Hold the vacuum and the plate should stay put. if it does not then the diaphragm is faulty (very rare).
                Everything should be clean and move freely otherwise it will not work.
                FYI, the vacuum mechanism is on metered vacuum from the carb. At high vacuum conditions like cruising (throttle open and not closed) is the only time the vacuum mechanism is in play. All other times like idle or acceleration it will retard back to its idle position.
                Mike Giroir
                79 XS-1100 Special
                • hondakid11
                  • Apr 2015
                  • 39
                  • Lockport, N.Y.
                  everything moves freely as far as i can tell. ill have to pull it all off and give it a good cleaning.
                  chopped rear
                  springer seat
                  led turn signels
                  led brake light
                  drag bars.
                  8" biltwell chumps
                  chopped rear
                    Remove the vacuum assembly, and THEN check that rotation of the advance assembly rotates freely, as in floppy free. If it's not, then that mechanical assembly and its little bearing need cleaned up first, THEN lubricated. Worn springs is NOT the issue.
                    • trdriver71
                      • 360
                      • Edmonton Alberta
                      If I were you I would check your valve clearances I had the same thing on my bike turned out that almost all of my valve were tight.
                      '79 XS11SF
                      • alaskey2
                        • Apr 2014
                        • 271
                        • 60940
                        Wait what? From my petcock I have a thick tube (fuel line) that goes to my carbs and then a skinny tube that goes to an intake boot. Is this wrong?
                        78 E
                          • 7763
                          Barb on carb #2 goes to vacuum advance (left engine cover). Barb on manifold #1 goes to vacuum shutoff (octy) on a Special, or the left petcock on a standard. Barbs on #2&3 are capped. #4 is capped on a Special and goes to the right petcock on a standard.
                          • Prisoner6
                            • Aug 2013
                            • 1184
                            • Phoenix, AZ
                            ... Barb on manifold #1 goes to vacuum shutoff (octy) on a Special, or the left petcock on a standard.
                            Marty,
                            On my SF, the #1 manifold barb is capped, and the vacuum line from the Octy is connected to the barb on the #2 boot ... does it make a difference?
                            Marco
                            1979 Honda CBX
                            2002 Kawasaki ZRX1200R
                            WE MISS YOU, DON
                              • 7763
                              Originally posted by Prisoner6
                              Marty,
                              No. You may run the vacuum shutoff (octy, octopus, spidervalve, POS) from any manifold you choose.
