Rising from the ashes
  • Blank Slate
    • Nov 2013
    • 393
    • Ottawa, Ontario, Canada
    Hey guys and gals,
    I need some help getting this bike started. I live by the airport in Ottawa and have lots of space to do the work. Zero know how.
    Below is a photo album of the cleanup work I'm doing on this bike. Just cosmetic/detailing at the moment. Baby needs a new seat asap.
    Frame: 79 XS1100S
    Engine: 81 XS1100S
    Carbs: 78-79 BS34
    Gf bike: 78 XS650S
    Carbs: 70-79 BS38
    • 8061
    It doesn't need a seat if it doesn't run. Put that off until the important stuff gets done.
    Step one is to get the manual and service everything.
    • Blank Slate
      • Nov 2013
      • 393
      Ok so I'm reading the manual.
      I get to the part about checking if your battery still has electrolytes, I figure the battery is dead so I skipped the test, removed the battery and bought a new one at CDN tire. Would you guys recommend putting in a new battery now, or keep doing maintenance in case stuff around the battery needs to be replaced?
      Another no-brainer is that this bike needs an oil change, so I bought a filter and oil to do an oil change. The manual asks for 20w40 but store said they don't sell that and gave me 4 bottles of 20w50. Would you guys recommend I do the oil change now (on a bike that prob wont start for a few months) or wait till the rest of the bike is fixed and ready to resurrect?
      I still want to buy a seat no matter if this thing runs or not
      The old seat is ripped and had a bunch of rust underneath. Yuck.
      Any recommendations for bike shops in Ottawa that have parts/modification options for my XS1100?
      Frame: 79 XS1100S
      Engine: 81 XS1100S
      Carbs: 78-79 BS34
      Gf bike: 78 XS650S
      Carbs: 70-79 BS38
      • mack
        • 2411
        • Ontario, Canada
        Bike
        Hi, I'm just up the road a few hours from you. Looks like you have a pretty good ride to work on there. Rob lives very close, probably a mile or less from you and Ernie is in Kanata. Look under the maintenance section of this site and you'll see one that says "what to do on a neglected XS11". It will guide you through what needs to be done. Basically though if the motor will turn over with the plugs out, it will run after you clean the tank, carbs and wiring harness connectors properly. For the most part these machines are bullet proof. Tires, brakes are always a good idea before you even consider turning rubber. My phone number is at the bottom of my signature.
        Mack
        mack
        79 XS 1100 SF Special
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        https://youtu.be/wB5Jfbp6SUc
        https://youtu.be/RaI3WYHSuWA
        Frankford, Ont, Canada
        613-398-6186
        • mack
          • 2411
          • Ontario, Canada
          Look Here
          mack
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          613-398-6186
          • Blank Slate
            • Nov 2013
            • 393
            Awesome Mack. I'll follow the links you gave me. I'm Sure they'll answer a lot of my questions and brring up new ones. I'll give you a call later today.
            You guys ever get together for barbeques? On the bbq I'm not a blank slate
            Frame: 79 XS1100S
            Engine: 81 XS1100S
            Carbs: 78-79 BS34
            Gf bike: 78 XS650S
            Carbs: 70-79 BS38
            • Blank Slate
              • Nov 2013
              • 393
              That's an eye opener!
              i was trying to drain the oil today but the exhaust pipes are in the way. Tried to remove the exhaust pipes but the frame is in the way.
              Gonna read the manual to see if I missed a step.
              Frame: 79 XS1100S
              Engine: 81 XS1100S
              Carbs: 78-79 BS34
              Gf bike: 78 XS650S
              Carbs: 70-79 BS38
                • 3953
                Must not be stock pipes. If you can get them on, you can get them off. T-handle Allen/Hex-head drivers are your friend. If they are stock pipes, you're not looking in the right area for oil filter and engine oil drain plug.
                • Blank Slate
                  • Nov 2013
                  • 393
                  I'm Looking to drain the oil from underneath the bike but as you can see in the picture that black bar doesn't let me remove a couple of the bolts. Does the exhaust look aftermarket?
                  Frame: 79 XS1100S
                  Engine: 81 XS1100S
                  Carbs: 78-79 BS34
                  Gf bike: 78 XS650S
                  Carbs: 70-79 BS38
                  • donebysunday
                    • Oct 2012
                    • 1737
                    • New Berlin, Wi.
                    Exhaust looks aftermarket to me and some retainers are stock and rusty and then the ones that are just bolts.
                    There is just the one big bolt on the oil filter.
                    76 XS650 C ROADSTER
                    80 XS650 G Special II
                    https://ibb.co/album/icbGgF
                    80 XS 1100 SG
                    81 XS 1100LH/SH DARKHORSE
                    https://tinyurl.com/k6nzvtw
                    AKA; Don'e, UD, Unca Don'e
                      • 8061
                      Yep. You're supposed to have studs in the head with nuts holding the retainers on.
                      • Blank Slate
                        • Nov 2013
                        • 393
                        Partial success today. Got the bolt loose but i could not get it out all the way so the oil cap wont come off.
                        Black oil flowing
                        [IMG][/IMG]
                        Frame: 79 XS1100S
                        Engine: 81 XS1100S
                        Carbs: 78-79 BS34
                        Gf bike: 78 XS650S
                        Carbs: 70-79 BS38
                        • Rasputin
                          • 3193
                          • Lacombe, Alberta, Canada
                          Mostly thinking out loud here, but would not this thread be best in the main forum? Some do not view here or check it often enough to bother to reply.
                          2-79 XS1100 SF
                          2-78 XS1100 E Best bike Ever
                          • Blank Slate
                            • Nov 2013
                            • 393
                            I dont wanna bother the entire xs1100 world for my canuck problems.
                            I'm Check in once a day and I find pple really good at answering my questions.
                            Frame: 79 XS1100S
                            Engine: 81 XS1100S
                            Carbs: 78-79 BS34
                            Gf bike: 78 XS650S
                            Carbs: 70-79 BS38
                            • Rasputin
                              • 3193
                              Well I do know that having all of the community responding to your comments does increase your knowledge. As well, it does add additional info for those who do respond, or even those who are lurkers or not yet members.
                              It is not my place to tell you where to post but I will tell you that many of us do have knowledge, which will not be shared if we are not monitoring certain threads. I myself have only seen your threads recently. It could possibly be that I know the answer, but if I do not see the question, I will never know.
                              Your choice. Ask all of the world who likes these bikes or only a certain few, who are Canucks, of which I am one.
                              Thing is the more that can see your post the more that can help you solve a problem.
                              2-79 XS1100 SF
