Rising from the ashes
  • mack
    • 2411
    • Ontario, Canada
    thread
    Ras is right. This tread should be up in the"general discussion" section. I saw it by chance and was thinking TC or Crazy Steve would move it.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
      • 6765
      Ras is correct this forum is for events in the Northeast... there is a technical forum where these questions would be more appropriately placed. I assure you no one feels burdened by your questions...its been played out here many times over...getting the attention of the real gurus in the technical forums is where you really want to be... Indeed TC ...we need to move this to the proper venue....
      2005 Honda SilverWing 600
      2018 Honda PC-Xpress 150
      • mack
        • 2411
        • Ontario, Canada
        pipes
        No he has a 4-1 on there and is experiencing the usual problem concerning oil changes. The drain bolt has to come out to get all the oil out. Pipes will have to come off to get il filter housing off.
        mack
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        613-398-6186
        • Blank Slate
          • Nov 2013
          • 393
          • Ottawa, Ontario, Canada
          I see your point. But let me get my feet wet a little before I expose my blank slate to the world. It Took me three days to find the oil bolt! Good news I got it off and let all the oil drain.
          Next thing I'd like to do is get the gas tank emptied and cleaned. Back to the manual
          Edit: just read the last 3 posts. I guess we're going primetime!
          Frame: 79 XS1100S
          Engine: 81 XS1100S
          Carbs: 78-79 BS34
          Gf bike: 78 XS650S
          Carbs: 70-79 BS38
            Hi Blank Slate,
            Definitely aftermarket exhaust. You will have to remove it to get the filter changed and with black oil definitely time for a filter change.
            DO NOT lose the spring and washer in the oil filter housing
            http://www.partsnmore.com/parts/yamaha/ have the exhaust gaskets and lots of other stuff you may want or need. They ship from Stratford ON
            • Blank Slate
              • Nov 2013
              • 393
              Hi Blank Slate,
              Hi Phil, thanks for that. Here's a safety question first. I fear this bike is going fall on me and crush me when I go under it. The only thing holding it up is the foot stand. Can I get something to stabilize it while I work on it?
              Once I get the bike stable I will feel comfortable tackling its many issues.
              Frame: 79 XS1100S
              Engine: 81 XS1100S
              Carbs: 78-79 BS34
              Gf bike: 78 XS650S
              Carbs: 70-79 BS38
                Hi Blank Slate. I use a floor jack at the cross piece infront of the engine to lift then place axle stands under the crash bars I have on both sides, then remove the jack. Ofcourse I put it on the centre stand first for this to work.
                You definitely must secure the bike before going under it.
                • mack
                  • 2411
                  • Ontario, Canada
                  I doubt
                  he still has a centerstand if he has a 4-1 header.
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
                  • Blank Slate
                    • Nov 2013
                    • 393
                    Costco has a low profile aluminum jack for cars around $210.
                    But I suppose I need one for motorcycles?
                    Like this? http://m.harborfreight.com/automotiv...ift-61632.html
                    Frame: 79 XS1100S
                    Engine: 81 XS1100S
                    Carbs: 78-79 BS34
                    Gf bike: 78 XS650S
                    Carbs: 70-79 BS38
                    • Blank Slate
                      • Nov 2013
                      • 393
                      Hey Mack, are these 4 aftermarket pipes of mine going to be a hassle moving forward?
                      Frame: 79 XS1100S
                      Engine: 81 XS1100S
                      Carbs: 78-79 BS34
                      Gf bike: 78 XS650S
                      Carbs: 70-79 BS38
                        • 6765
                        hassle or not theres not much out there to replace them with...you'll have to look pretty hard...OEM is gone and there are no aftermarket companies making an exhaust for our bikes anymore...yes the headers have to come off to remove the oil filter...welcome to the club...LOL
                        • Blank Slate
                          • Nov 2013
                          • 393
                          Lol, oh well. so is using steel wool on the pipes to remove rust a good idea? Tons of rust underneath but I am worried I'm going to put a hole in them and really be screwed
                          Frame: 79 XS1100S
                          Engine: 81 XS1100S
                          Carbs: 78-79 BS34
                          Gf bike: 78 XS650S
                          Carbs: 70-79 BS38
                          • CaptonZap
                            • Jun 2010
                            • 1748
                            • Denver
                            No, that will impede the removal of the pipes and filter housing. What you want is one like this,
                            As was stated, it is placed under the cross bar at the front of the frame, and then raised until the sump is level, or sloped to drain. If placed correctly, it should not interfere with the pipe removal.
                            It, the jack, should be allowed to roll back as the arm is raised, since if it isn't, it can pull the bike forward off of the center stand.
                            cz
                              I see bolts in 2 an 4. I hope they won't be a serious issue, but they need to go. You need to go back with studs. OEM style nuts are still available, but not absolutely necessary.
                              • mack
                                • 2411
                                • Ontario, Canada
                                Exhausts
                                I have a good set of OEM headers (2-1) here you can have, to clone on an aftermarket exhaust system. This will restore the ability to have a center stand and removal of the fluid drains and oil filter housing. You'll have to graft on exhausts to the headers but there are lots of " how to threads" on that. I'm not a welder but I'm sure madmax could walk you through it. Back those bolts out of the head while you have the 4-1 off and put the proper studs in. I have a couple extras here with the nuts, but there was two sizes used and I'm not sure which you have. If you can back out one of the OEM ones, you can take that to Napa and they can probably hand a couple new ones right over the counter.
                                mack
                                HERMES
                                original owner
                                81 XS 1100 LH MNS
                                SPICA
                                78 XS 11E
                                IOTA
                                613-398-6186
