Site was down for about 2 days, give or take. It does NOT happen that often, and with luck will not happen again.
Try to get OEM Yamaha front seals for the forks, and you can replace them yourself. It isn't that hard, and you could probably do it in one day, for about $35 total.
Flush the brakes first, then just clean the seals on the calipers. Biggest thing, clean the grove the seal goes in REALLY WELL. I took a small, flat blade screw driver and bent it so it will fit inside the grove flat, and use that to clean it. With fresh brake fluid, you may not need to replace anything in the MC's.
150 RWHP... don't know if I can, but I WILL try....
