Showa vtx1300 Shocks for the XS?
    • 8062
    I believe 25 mm laden sag is a good number on the track. If you run over a dime, you might be able to tell if it's heads or tails.
    • Orange4
      • Sep 2013
      • 398
      • Maple Ridge, B.C., Canada
      #47
      I love Skettis too. What are they? Edit: D-oh!
      Started with 320 grit on a random orbital (you could do this by hand with 220 and a block) to get rid of factory marks and corrosion, then wet 400 by hand, then 600, then a hard polishing wheel with green bar, then soft buffing wheel. Got the buffing machine at a garage sale. Was a jewellery unit. Still is, I guess. I have done alum polishing completely by hand as well. You just go up to 1500 grit and then buff out with Autosol. Takes longer and your fingers are sore by the end but when you are 20 and desperate for polished mags you do crazy stuff. I'm older and wize... well, um, I'm older now.
      Marty, I'll let you know. Heads, I win. I'm actually dying to do a track day at our local joint. Are there fork tops that don't have as much depth to them already? I don't really want to cut anything. OTOH, I already just modded my damper rods permanently.
      Living to EXcess.
      1979 XS1100F Canadian, stock exhaust. Top end rebuild in progress.
      • Orange4
        • Sep 2013
        • 398
        #48
        Took it for a ride today. It's much better now, if a bit stiff. Dive is waaaay down and there's actually rebound damping now. It used to bottom on heavy braking. Bike is transformed but needs tuning. Didn't really get to wring it out. I'm pretty sure I'll cut the preload plunger back and see how it is after that.
        Steering is heavier because the driver sag is less than half what it was so the steering angle changed.
        I'm also going to see if I can put softer springs in the rear shocks as they do come apart.
        It's a good thing I like tinkering.
        Living to EXcess.
        • Orange4
          • Sep 2013
          • 398
          #49
          Am I right in assuming that the air assist forks have mo mechanical preload adjuster? If I could find a pair of those then I would not have to butcher a set of normal ones. Also, It would probably give me the 18mm less preload (emulator + difference in spring length) I'm looking for, whereas cutting mine down would only give me about 10mm less preload.
          Living to EXcess.
            • 8893
            The threads are the same and there is no preload adjuster in the air caps. The problem lies with the depth of the thread. Look towards the bottom of this thread for more info...
            • Orange4
              • Sep 2013
              • 398
              #51
              There may be an aftermarket cap like these:
              Living to EXcess.
                • 3954
                Can't recall if "cannot remember his name" ever tried the '80 head on '78 engine, but you may be the first to do so all the way. I know there was some clay testing, etc. If it works-out, please give us a report.
                Oh wait, ur using '80 cylinders too. Just remember hearing a head swap.
                • Orange4
                  • Sep 2013
                  • 398
                  #53
                  That's on the back burner but there's plenty of valve clearance even with no base gasket. I still have to calculate compression but I'm sure I can get it up there, if I have to, without shaving the head with a thinner copper head gasket and no cylinder base gasket.
                  Living to EXcess.
