Petcock Sealing Washers
    • 4015
    The sealing washers that go under the head of the bolts that seal the petcock to the tank. I know the part numver, etc. Done the research on them. Need to be fuel resistant. Viton is recommended. Anybody use anything else that works? Copper crush washers?
  • MPittma100
    • Aug 2011
    • 2359
    Washers
    Just bought some of the OEM replacements. Have not tried anything else since these are still available. OEM screws are also available.
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
      • 8963
      Fiber washers are correct for this application, they need little torque to seal the fuel and are rigid. I would imagine copper crush washer would need a higher torque which may not be a good thing here. Rubber viton may be too soft and would deform when tightened I would think.
        • 4015
        U paid $4+/each for four washers?
          • 2104
          Fibre washers can be found at a good local hardware in the fastener section.
          • MPittma100
            • Aug 2011
            • 2359
            Washers
            I paid $1.78 each for the washers plus shipping from Partzilla. Bought the screws as well - same price each.
            Or I could have wasted time and money on gas running around hoping to find something that "might" work.
            On the other hand, if the correct part is no longer available, I will waste time and gas money to find something that may work.
            K&N Air Filter
            ACCT
            EBC Front Rotors
            Mike
              Time is money!
